Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor is blank, help
Greetings,
I have a monitor problem and it has to be on the circuite board.
When I hook up the monitor(external) to my laptop and turn it on the LCD flashes the screen once and then goes blank with a little hint of flashing every time the power buton flashes(green only). I have come to the conclusion that the LCD itself is fine but the monitor had dust on it when I got it. i'm sure this is the original cause, but not sure what exactly it could have effected. i have pics of the circuit board and so forth. I can provide that, and I'm also uploading to youtube a short video of what the screen does when I turn it on. I hate to see a perfectly good LCD go to waste because one transistor . I'm not a technician but can understand any sugestions you might have.
my email is - nolamikec@hotmail.com
please help
Michael
  • 472 Answers
You have bad capacitors on the power board. If it was the inverter and the transistors associated with that then you would still get a solid green power light and shining a bright light into the screen would reveal an image.
Easy to repair if you have some electronics knowledge, if not, then your local TV repairman should be able to help you out.
Hope that helps =)
Posted on Apr 10, 2008
Compaq Presario v4000 will not boot screen stays blank
Overheated chipset/VPU. It needs resoldering.
Oct 09, 2014 | Compaq Presario Notebook
My laptop Lenovo G-580 has blanked out...not starting. Please help.
Check google for this. Lenovos have a habit of just dropping dead.
If you hit some key combinations it will reset the unit and then work.
If that does not do the trick then you have some serious problem. Hook up another external monitor - if that works then issue is with your built in screen - if external monitor also dead then you have a boot up issue with the mother board. Not good.
Sep 06, 2014 | Computers & Internet
Blank Screen
hook the laptop to an external monitor and see if there's a display. if it does then your laptop screen or cable that connects your screen to the main board is faulty/loose. bring it to a computer repair and see what they can do about it.
Jan 10, 2014 | Sahara AL-096 Laptop
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
Hi, my hp compaq nc6220 switches on but the screen wont light up
Hook a external monitor to the video output on the back of the laptop, if monitor works, it means that the laptop screen has a bad inverter board or back light issue. If the monitor has a blank screen like the laptop, the video graphics card is bad, or you have motherboard problems, suggest a computer tech.
Jan 05, 2011 | HP Compaq nc6220 Notebook
Dell M2300 issues: After several times of a freezed screen & rebooted the computer while either on the internet or working with "Autocad Inventor", it's finally gave up on me, on the last...
Isolate where the problem is: it could be the LCD display or the graphics circuit on the main board. Connect the VGA output of the laptop to an external monitor - one that you know is good. From the function keys, activate the VGA output of the laptop - it's suppose to switch between the LCD display or to the external monitor. Switch it to the external monitor. If the external monitor works, then you have a problem with the LCD display of the laptop.
Dec 22, 2010 | Dell Precision M2300 Computer Workstation ...
My laptop comes on, and the screen stays blank, (black ) nothing, I tried hooking up an external monitor but it does nothing also, could the invertor be the cause? Unit is a Sony VAIO PCG-TR3A
If the invertor was faulty you would get a picture on the external monitor, assuming that the external monitor and the laptop was configured to work. Check the Fn key and F5 at the same time. That should switch between internal/ external or both displays.
Hope that helps.
Dec 09, 2010 | Sony VAIO PCG-TR3AP1 Notebook
My laptop screen is gone blank. the power lights are all on e but the screen is blank...what shouyld i do...pls help!
Perhaps it is your Inverter Board, Either that, or your video card is kief.
uh, hook to external monitor, if it works.. its not your video card ;P
or,perhaps, you need further assistance by taking it to a laptop tech to resolve this issue with some hands on work
Sep 13, 2009 | Acer Computers & Internet
Dell Inspiron 700m blank screen or won't boot
The problem you are facing sounds like either a video board problem, which I believe the 700 is hard solered onto the motherboard or an inverter board. The best way to test this is to hook up an external monitor to your laptop and see if the problem persists. If the problem does not appear on an external monitor, then the problem is most likely the inverter board in your laptop. If you are still having the problem with an external monitor, then your video card is at fault. The video card on this series I believe is hard soldered to the motherboard and cannot be replaced without changing out the motherboard. If the problem goes away with an external monitor then you just have to replace the inverter board on your laptop which you can pickup on eBay for around 30.00 + shipping.
Jun 29, 2009 | Dell Inspiron 700M Notebook
Display Problems
your gpu has failed - thats graphics processing unit. new m/board required
Jul 12, 2008 | HP OmniBook XE3 Notebook
Dell E173FP 17" LCD Flat Panel Monitor Logo
Alun Cox
