Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Tractor dies tractor starts fine and runs great for about 10 to 15 minutes then it dies just like you shut the key off. Then it will not fire or start until it cools off.
My lx173 quits running after a while and will start back up and run for a while longer and quit again
Posted on Jun 13, 2011
  • 66 Answers
Good chances is that you have a coil issue. Some coils will go quickly while others go gradually. If it starts fine again after it cools off...replace the coil.
Is there any fuel in the line when it quits? www.nnyparts.com
Posted on May 30, 2010
How to fix 1957 ford 960 tractor that starts runs dies
Fuel flow issues can cause this. Clean out the filters and fuel line ensuring a good flow.
May 18, 2017 | Ford Cars & Trucks
1996 dakota v6 starts dies but then wont start till time has gone by
Just a thought! There is a provision where when fuel pressure drops the ignition is shut off. This is to prevent pumping when the fuel line is compromised. Monitor fuel pressure to see if it drops during normal operation.
Apr 05, 2012 | 1996 Dodge Dakota
After running 2 minutes tractor cuts off
The fuel not going to carb.
Mar 03, 2012 | Ford Garden
The tractor was running just fine, shut it off and it would not restart. I can jump across the solenoid, it turns over great, choke it, smell gas, but no spark. tried to bypass the interlock in the...
Hi you mdont say what make or model tractor you have . try disconnecting the kill switch wire directly at the engine and then try restarting it if it starts the problem is in the safety switches or ignition key or a shorted wire -- if it doesnt start and still no spark then test the coil .
I Hope this Helps Andrew A
Apr 11, 2011 | Garden
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere 42 inch,17.5 hp-was running good then just died-will start back but will only run about a minute and die again,clean air filter,changed fuel filter,checked fuse -ok, module on side of engine...
have you had a look at carb side of things as it may be having fuel starvation probs.. the fuel in line not getting through jets or float chamber cleanly.. also the tank might have contamination from rust or debris..
Aug 13, 2009 | Garden
1997 Jeep Grand Cherokee cranks but won't start
Same thing happened to me at about 140k. It was the fuel pump. Best way to test if your pump is failing and loosing pressure is to see if the car will start immediately after it has been running, or turn the key to the alt position for a few minutes before starting. If your engine fires faster after it has been running or the key has been in the alt position you will probably need a new fuel pump. Great news is with a very deep socket to get the tank straps off its a 30 minute job to replace the pump/filter assembly.
Dec 17, 2008 | 1997 Jeep Grand Cherokee
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
730 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
