Question about Mitsubishi WS-55511 55" Rear Projection Television
Help i have a 5-10 year old 64 inch mitsubishi projection tv and when we moved it now has jumping snow at the top which jumps to the bottom and lines in the middle going sidways like fuss
  • 21 Answers
Soulds like a cold solder joint that was disrupted during the move..or a cracked board..or a dislodged connecter. Unplug, remove pack. Take ntes..remove chassis boards...clean with compressed air. Chk for cold solder spots..heat stress. Repair. Reinstall board..noting where all connectors go. Good luk. Anything more..could need servicing..burnt out capacitor,,etc.
Trace Electronics, Barrie, ON
Posted on May 29, 2010
Testimonial: "thanks but i think if i have to do all that i will wait for a repair man"
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
I have the same problem with my tv, my tv tech said mitsubishi knows of the problem and knows how to fix it, but it would cost me 700.00 plus his labor to take out the chassis and send it in to mitsubishi, plus I would be without a tv for up to a month. this is b.s.
Oct 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
sounds like dm module
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Year 2000 mitsubishi 64 inch tv
Have convergence IC's changed in your 60" TV. I only use ORIGINAL IC's, not generics or knock offs. Most companies that fix have no idea what the difference is.....
Oct 31, 2007 | Mitsubishi VS-60703 60" Rear Projection...
TV
The tv have vertical problem, some leaked electrolitic capacitor. You need a proficional to help you.
Sep 07, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
