I have a Whirlpool Duet front load washing machine (GHW9300PW4). I believe the connection on the control panel is loose. How do I get to that connection?
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
Make sure that electrical power supply to the machine is switched off and water supply is secured, before starting to fix the problem in your washing machine.
Faulty water pump, timer switch, lid switch or off-balance switch also causes the machine to stop working. In that case, these switches need to be checked and replaced, if necessary. If there is a problem in the motor binding, you need to get it repaired by a service engineer.
Please check this link to have an in-depth knowledge about your problem…
http://home.howstuffworks.com/how-to-repair-a-washing-machine4.htm
Let us know if you want to know something more else please accept the suggestion.
Thank you.
Posted on May 29, 2010
Whirlpool duet washer GHW9300PW4 .... The control lock is on .. I did get door to open, It will not shut off and none of the cycles will light up or start.. Please help..
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My front loading washing machine started and then displayed f1, now it will not start at all and when I pushed the start button it beeps three times and does nothing.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet HT GHW9300PW4 - The control lock is on
Hold down "end of cycle" button for 3 seconds.
chrisxx
Jun 03, 2009 | Whirlpool GHW9300 Duet Washer
Machine won't turn on flashes dL F code and gives me short buzzes
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool Washing Machines
It should be the end of cycle signal volume botton
Aug 04, 2008 | Whirlpool GHW9300 Duet Washer
Sometimes leaks from the bottom
ckd door seal closley for tears or distortion..try removing bottom panel for a few loads this may help in locating source
May 21, 2008 | Whirlpool GHW9300 Duet Washer
Washing Machines Logo
Top Washing Machines Experts
