Question about Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250
Robot not climbing walls, is vinyl pool too slippery?
    President:
  • Smart Master
  • 1,378 Answers
Yes...a set of climbing rings will probably need to be installed. To have it done under 'warranty' for a newly purchased unit contact Maytronics directly or use our dolphin serice button found at www.arrowpools.net.
Posted on May 29, 2010
Navigator will not climb walls
You may need to replace the feet/shoes?
Or you may not have the proper feet to begin with?
Vinyl
Fiberglass
Plaster...
all have their own specific shoes.
Sep 30, 2014 | Hayward Navigator Pool Cleaner
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
Why does the n71 not climb walls or slope
check drive belts or worn out paddles if ok check inside to see if motor is weak
Jun 24, 2014 | Smartpool Nitro Robotic Cleaner and Caddy
Dirt Devil Rampage Robotic Pool Vacuum wont climb side and stays in deep end all the time?
If a pool vac is not climbing the side of the pool this is one of several things main things . a blockage in the pipe (try inserting garden hose to flush it. or insufficient vacuum at the skimmer box (Test with your hand) or a break inside the unit - if the third, you probably need to take it in for repair.
May 17, 2014 | Dirt Devil Rampage Robotic Pool Cleaner...
Problem with the Aquabot Robotic Pool Cleaner Just
The service center is stonewalling you; contact them again and demand they look at it. The unit should run consistently regardless of water balance. Water balance will affect the lifespan for a product like a pool cleaner but not whether or not it works at all. As for climbing, water temp plays a roll but 65 should be enough...what material are the pool walls? Fiberglass or some lines are too slippery for the standard brushes to climb efficiently. The service center should be able to recommend any changes that may be required due to certain pool materials you may have. Discuss that issue further with them or the manufacturer.
John
Mar 29, 2011 | Aquabot Robotic Pool Cleaner
The dolphin maytronics does not climb the wall
Thank you for posting your question here on Fixya.com.
Several possibilities to consider...
How old is the filter bag and is it clean?
Older bags or bags not thoroughly cleaned can resist water passing thru them to the point there is not enough downward pressure to allow the unit to 'bite' the pool surface and climb.
How worn are the brushes and tracks?
Worn brushes and tracks will slip once worn enough. Replacing them could fix the problem.
Is it trying to climb or does the unit start up the wall and immediately reverse?
If your motor has been replaced new style motors spend far less time climbing assuming most debris will instead be found on the pool floor. If it has not been recently replaced the program within the motor may be failing.
What is the condition of the pool?
Low water temperatures and/or algae can cause the unit to slip in place and as a result it will not climb. Eventually it will scrub enough to gain traction and will slowly progress up the wall. For temperatures below 70 degrees the unit will find in more and more difficult to climb the lower the temperature.
What material is the pool surface?
Some linered pools and fiberglass pools require climbing rings in the brushes. Do you have those? If so, what condition are they in? Worn rings or missing rings will prevent climbing those and other smooth pool finishes.
For more troubleshooting tips try our site at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. You can also check the manufacturer's site at www.maytronicsus.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Dec 31, 2010 | Dolphin Maytronics Diagnostic Robot...
My cleaner works for a few minutes, climbs a wall and rolls over onto it's head.
If the problem always occurs when the pool cleaner starts to climb walls, there are a few things that you will want to check. First of all, if your pool has a vinyl liner, this pool cleaner has limited climbing ability. You need to check the flow of water through the cleaner with your flow gauge. It might be low. If it is, increase the water flow. Also, make sure that your hose weight positioning is correct. The cleaner should sit at a 45 degree angle at the bottom of the pool when resting when the weights are right.
Nov 08, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Nitro N71 does not climb the walls of my Acrylic mosaic swimming pool. I fitted the replacement front and rear paddles with the foam wheels but this did not do the trick.
None of the robotic cleaners are going to climb that surface well. Off all the options out there the Aquabot with the foam brushes is likely your best option for an acrylic pool. The Dolphin version can have rings added to their brushes but that may not be enough. You may try to get a rental unit from a local shop or pool store to try out before committing to the purchase so you will know if it work before buying it.
John
Oct 21, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
What is the difference between the red light and green light?
my wall climber only wants to climb the walls. it won't run in a straight line. it only cleans a small part of our pool.
Jul 06, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
Wondering if a robo-kleen robotic pool cleaner can be used in an inground pool?
You will find it won't climb walls, but should clean just fine on the bottom area.
S. Christian dansker01@msn.com
Jun 05, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smart Pool Inc Dolphin Diagnostic Automatic Pool Cleaner Ne250 Logo
451 people viewed this question
Top Smart Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Robco Water
Robco Water
Bill Boyd
Are you a Smart Pool and Spa Expert? Answer questions, earn points and help others
