Question about Intel Motherboard
Install IDE devices (drives / DVD / CDROM) sata
    Brigadier General:
  • 10,406 Answers
IDE devices have different "data" and "power" connectors than SATA drives.
So, you need a motherboard with IDE connectors, if you wish to connect an IDE disk-drive (or CD/DVD), and you need a motherboard with SATA connectors, if you wish to connect a SATA device.
Similarly, the connectors on the power-supply must be compatible with the sockets on the disk-drive (or CD/DVD) drives, so that the devices can get power.
You could possibly purchase a short IDE-to-SATA power-adapter, if you have a SATA device, but there are no SATA power-connectors on your power-supply.
Posted on Jun 15, 2010
Dont know where to plug in cd drive
You have to identify first what kind of interface your CD-ROM uses. This can either be IDE or SATA.
Note that for IDE interface, there is a master/slave/cs settings for the device. If you are using one cable to connect the hard disk and the CDROM,make sure that the settings for the hard disk is set to master and CDROM to slave. If the IDE cable you are using has a twist on it, then both device should be set to CS (Cable select)
For SATA, this is just point to point. Please check below link for more details.
http://it.flexinet.com.au/bits%20and%20pieces/HARDDRIVES.htm
Jan 07, 2011 | Intel (AXXSCD) Internal CD-ROM Drive
ASUS M2N68-AM SE2 GeForce 7025 Socket AM2+ MB built system. Works great with Sata hard drive. Removed my older 500GB IDE hard drive and CDROM from old PC. When i try to put both, or either 1 into to IDE...
Try to go into the bios and set the first boot device as your sata hdd. There will be a option in boot section of the cmos setup where the hdd drive order will be mentioned. If PATA is shown first press enter in the option select SATA and press enter save and exit changes things should go on fine.
Also check your pata hdd and cdrom specific jumper setting. For more help post your HDD model and make and cdrom model and the bios type
Dec 01, 2009 | Computers & Internet
Samsung cd-master 40e will not boot
Is this conected to the motherboard vis sata or (ide)pata?If sata did you put it in the correct port and if so is it enabled.Secondly if ide or pata is the port enabled in the bios or do you have a second device attached to it.If using ide pata one drive should be master or slave ,,, or cable select.
These are the answers why it might not work.The last answer is it died,but i think this is the least likely answer.
good luck
Sep 17, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
How to install Redhat Linux 4.0 on Acer Power Series with SATA.
So did you try to install with and IDE dvd drive? Might be a BIOS issue, update bios or get a ide dvd drive somehow...
May 06, 2009 | Acer Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Problems with windows.
  1. Are you using a SATA drive or an IDE(PATA)?
  2. If using SATA, is SATA set up in bios as first boot or second after CDROM?
  3. If using PATA hard drive is the IDE channel working properly? Switch the CDROM and Hard drive ribbon cables on the motherboard.
May 10, 2008 | Foxconn 661FX7MF-S Motherboard
CDROM and with a bootable CD is not been detected
Same solution as posted before if you need to boot from a DVD: take a Dell laptop CD/DVD combo drive, remove the screws and all and exchange the PowerVault CD drive unit with it. Same internal connector. Can't remember what model I stuck in, but I had to keep the front panel of the drive since it was slightly different, I probably could have glued it, but.... That's a server machine no one is ever going to see but me! :)
That also gave me a CD-Burner which is a decent addition in case you need to quickly burn a CD/make a backup/boot disk (like a "ultimate Windows CD" boot to fix anything that could go wrong).
Nov 29, 2007 | Dell PowerEdge 2600 Server
Intel Motherboard Logo
174 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
