Question about Kenmore 23822 Top Load Washer
Whats wrong when the bottom spins but the top doesnt
The top will not spin but the bottom part will
  • 159 Answers
It is normal for the top half of the agitator to turn separately from the bottom half.The top half is called a clothes mover,it twirls one way when the machine is washing drawing the clothes downwards.If it is no longer turning in one direction it need a new dog & ratchet kit installed down the centre.
Posted on May 29, 2010
My washing machine does not agitate, 2009 is when I purchased it.
Their is 1 of 2 things wrong causing it to not agitate..does it also not spin or just the upper portion of the agitator doesnt turn while the bottom does??
these tips i wrote will cover the 2 different things that are causing it not to agaitate depending on if it also spins or not
JUST BOTTOM OF AGITATOR TURNS BUT NOT THE UPPER BARREL.. http://www.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
DOES NOT AGITATE OR SPIN http://www.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Aug 31, 2011 | Roper Washing Machines
The washer no longer seems to spin... during the spin portion of the cycle it lights up saying it is spinning, but you can see inside that it is not physically spinning. The clothes are left dripping wet...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | GE WSXH208A Front Load Washer
MY WASHER DOESNT SPIN OUT YOU HAVE TO KEEP GOING IN THERE TO ADJUST THE CLOTHES TO MAKE IT SPIN
i am assuming this is a top load. if so place a screw driver in the lid switch button, turn dail to spin and while holding the spin basket in place turn on. is it very easy to hold basket from spinnihg? if so you may have a slipping clutch. to replace, remove washer body by removing 2 screws from timer console. they may be in front or behind. remove body clips located under timer console and lift off body. next remove agitator. next remove 3 , 1/2 inch bolts at bottom of transmission. slide out. clucth is right there on top side of transmisson. part # 285785
can be purchased at repairclinic.com
Jan 29, 2010 | Whirlpool Washing Machines
WASHER WILL NOT SPIN
replace the belt
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Experiencing a lot of dirt still on clothes
Check to make sure your agitator is working. The agitator comes in 2 sections, a top (#3) and a bottom (#4). Spin the top section clockwise and than the opposite direction. It should spin free from the bottom section in one direction but when turned the opposite direction it should spin the bottom with it. Hopefully that makes sense. If it doesnt, you need to replace the agitator dogs (#10). Very simple to do. the part # is 80040 and theyre about 8.00. Hope that helps. Let me know if you need help with the install or the par itself. dave www.washermd.com
Dec 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not dash during use after clothes are added
Oct 23, 2008 | Whirlpool LSR5132PQ Top Load Washer
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Kenmore 23822 Top Load Washer Logo
112 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
