Question about Maytag M6X06F2A Air Conditioner
My m6x06f2a-f is leaking from the front water is coming out the outside of the unit ok . also how do you take the front cover off i removed the 2 screws on the side but can't remove the cover.
  • 3 Answers
Lift the left and right side straight up till you feel each side pop out. Then it comes straight off. I can't find a manual, but this maytag would be a Fedders-Airwell air conditioner with the same model numbers but starting w/ an A instead of an M.
Posted on Mar 26, 2011
The floor of back passenger is saturated in my holden barina 2004
Hi Water leaks can be a pain to solve. There are three possibles (1) Main cause obviously water comming in from outside ie, rain or driving through mass water on the road. (2) Water coming from cooling system entering via the heater at front. (3) air conditioner unit normally the drain leaking back into car. Because the floor slopes to the rear don't rule out the fault being at the front. If your engine has coolant in the cooling system water entering from cooling system will have a sweet smell if no smell you can normaly rule out the heater leaking however check level of coolant Make sure engine is cold. If you run your hands around the heater unit front centre inside car check for any wetness around heater and carpet. If these areas are all ok its a matter of hunting down a leak from outside. You will need a second person to spray the car with a hose whilst the other sits in the car and checks all possible areas. There are no known areas for water leaks but due to the age of the vehicle check for any cracked or shrunken rubber seals. Good luck
Aug 06, 2017 | Holden Cars & Trucks
How do you remove front panel on unit?
It is highly likely that the condensate drain line is blocked and water is building up inside the unit. Find the drain line on the outside of the house and clear the blockage in the end of the pipe. The pipe typically just runs onto the ground, but may go into the gutters if the unit is on the roof. Occassionaly the blockage will be inside the indoor unit, but this is rare, so check the outside first.
Jun 16, 2016 | Heating & Cooling
I have a leak somewhere.where could it come from?
check the pipes from the water main and the pipes in the machine could be a seal has gone
Feb 19, 2016 | Kenmore HE2 Plus Front Load Washer
Leaking water
If the hose is ok and you need to check if the leaking coming from the seal of the rotating shaft you can check when you remove the cover behind the machine if it is ok check the rubber seal of the front door
Regards
Mar 31, 2014 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag M6x06f2a which has served me well for quite a few years and this year has developed a water leak in the front of the unit. The filter is clean and the unit has over an inch of tilt to ...
Some of these units have a kinda clip on the bottom If its been a while since its been serviced it may take a little kick to get it off. You shuld be ablt ot pull it down a bit and then pull out from the bottom. Or perhaps a but of hat water along hte edges will help .. Clean it carefully and don't get any electrical wet . Jon
Aug 08, 2011 | Maytag Chassis Built-In Air Conditioner...
My quiet master is leaking water inside my store.How can I drain the water.
1. check the filter.2. remove the front cover and check the front coil behind the filter and check any drains that might be plugged. some units do not have drains and if not that is fine. 3 Be certian that the unit is tilted to the outside about 1 inch or so.. It should then drain as it is designed.. hope this helps let me know.. Jon
Aug 03, 2011 | Friedrich QuietMaster SL35J30 Air...
Water coming out of front of unit, thru vents leaking on floor
Darlene, if this is a window or thru the wall unit, the leaking is usually caused by two things:
1. The drain pan under the unit has a drain hole (in the rear outside part of the unit) that is clogged.
2. The AC unit is not tilted down at the rear 1/4" to 1/2", so that water will drain to the outside drain hole.
Be prudent when you look for the drain hole in the drain pan. As the clog can blend in with the drain hole, making it difficult to see.
Hope this helped you troubleshoot and solve the problem.
Jul 18, 2011 | Haier Heating & Cooling
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
Jul 04, 2010 | GE ASL05LA Air Conditioner
Leak
bad pump..take some news paper and slide in from bottom you will notice that the drip is coming from the left side more,,..if you can get behind unit theres 2 green clips on the right and the left remove these,,if you cant get behind remove front panel ..and remove from front...slide lid forward than remove lid switch connection right front corner,,now the tops off...remove the 2 screws holding washer front panel..now your in ,,to put back reverse...att'' always unplug unit first
Sep 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
Samsung side by side
This is an issue brought about by the defrost cycle. Usually, the condensate goes into a small pan under the unit where it evaporates. You will likely find that the tubes coming down from the unit to the pan underneath the box are clogged with dust. While you're there, clean the condenser coils.
Dec 30, 2007 | Samsung RS2534 Side by Side Refrigerator
Maytag M6X06F2A Air Conditioner Logo
342 people viewed this question
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
