Question about Garden
Riding mower 14hp briggs & stratton will not stay running, new solenoid, new spark plug, new air filter, new fuel line and filter. At first it didn't want to start solenoid fixed that. It started ran good went to engage blades it died, now it starts but dies shortly after. plz help!
  • 279 Answers
Check the belt/s and make sure they are clear. If they are okay, check the governor spring. If the spring is gone, it will start but as soon as a load is put on it will stall. Good luck...Lee
Posted on May 29, 2010
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
We have a murray riding lawn mower 287707 it turns over and it wont start. Spark plug new and it sparks and just changed oil, cleaned carbuator, new fuel line and new air filter we tried everything. Can...
on the bottom of the carb there is a solenoid if that solenoid doesn't have power it shuts it off a bad safety switch will cause it to not have power if so start with the clutch/brake switch
Jun 03, 2012 | Briggs & Stratton Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
I have a briggs and stratton ride on lawn mower 14hp model 287707. engine pumping oil through breather into carburettor when running, its working but burning oil.
The float is getting stuck open which will cause the engine/sump to fill with oil and thats why you see oil comming out carby/air filter clean ya plug drain your sump turn motor over with plug out a few time to clean out check float/needle and seat in carby refil oil clean ya spark plug and off you go it will blow heaps of white smoke don't worry it is just buring th oil out if the exhaust/engine hope this helps some one
Mar 26, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Starts but won't stay running
It sounds like you are getting a vapor lock.
Try getting the fuel line and fuel fillter away from the motors heat.This will cause the fuel to boil and give you trouble. Check all your electrical connections for that clicking problem. Make sure everything is clean and tight. Check your spark plug gap.
John
Sep 27, 2009 | Garden
I HAVE A 14.5HP BRIGGS AND STRATTON ENGINE AND IT WILL TURN OVER AND WONT STAY RUNNING
definetly fuel problem but make sure you have new spark plug, then make sure air filter is clesn, then clean ot fuel tank, then run some carb cleaner spray while trying to start, just takes small grain of dirt o clog up carb, blow out all fuel lines, or replace
Sep 02, 2009 | Briggs & Stratton Garden
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
14 hp briggs runs fuel filter dry every 15 minutes. have to blow into fuel tank to fill filter up then it runs for a while again. whats up ?
Sounds like the tank is not venting. Try leaving the cap a little loose and see if it stays running. If it does, either the vent for the tank or a vented gas cap is plugged
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
