Question about Jenn-Air JGW8130A Electric Single Oven
Model jjw833odds key pad will not work - Jenn-Air JGW8130A Electric Single Oven
Error code SAb bath on Jenn Air oven. Held clock button down for 5 seconds and key pad still will not work.
possible need new key pad.first check no loose connection from key pad to the control board,if not replace key pad
Nov 24, 2013 | Jenn-Air Ovens
F0 Error code
your model number please?
Jan 21, 2008 | Ovens
Key pad problem
what can i say Maytags have many key pad problems, it is very easy to replace you will need the make , model, s/n to order the key pad board, and the board also has a number on it , The dishwashers are rally bad for keypads
Jan 19, 2011 | Maytag CWE4800A Electric Single Oven
Oven wont heat up, F-1 on timer
This indicates the ERC Electronic Range Control has failed. First check the key pad. Press each button one at a time. You should feel or hear a click and feel the retraction. If any button is not working the problem is likely in the key pad. If you locate the tech sheet ( somewhere on the stove, usually in the control panel) it may have a ohm check that can be done on the key pad to rule out the key pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control(ERC). If all seems good the control is at fault. Check to see if you have power going into the control. If you do and nothing is working the control board or ERC needs to be replaced. Here is a link for checking and replacing an oven control. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 22, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Controls won't work. Oven displays F7 error. Reseting oven or cycling power does not fix problem
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
  • NOTE_ Some models incorporate the touch/Key pad into the ERC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the ERC (Clock).
Aug 23, 2010 | GE Profile JKP18 Electric Single Oven
F1 keeps flashing
HI. This is a basic communication issue that will concern either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
If code does not recur, problem is with the Key Panel membrane switch.
Jun 12, 2010 | Magic Chef Ovens
I have a 24" single gas wall oven model JGRP17VEW4BB and it is displaying an F7 error code and the time. I've tried shutting off the power but it comes back right away. Do you know what part I will need...
Jan 17, 2010 | GE JGRP17 Gas Single Oven
Kenmore model 911 4238816 - the f7 code just came on beeping and we can't get it to stop. what is the error code mean, what can we do to stop it
HI. This code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
Jan 03, 2010 | Kenmore Ovens
We get a F7 error code on our model JT910SA3SS
F 7 code is an most G E ranges . is stuck key on pad . some of these can be unstuck but if hi heat caused the pad is warped and not repairable . turn off power disconnect the key pad from the clock and if code goes away key pad is at fault if it does not the eoc is at fault . and you will have to replace the clock . **** hope this helps . feed bk pls .
Dec 26, 2009 | Ovens
Beeping with f7 display
HI this is a touch pad or key pad issue. In most models, the touch or key pad are integrated. In this case, you will need to replace the entire control board or EOC(clock).
Now, if the touch or key pad is separate from the main control board, and linked, via linking ribbon, i would advise to use the procedure below to isolate the problem area.
Determine if problem is with the Key Panel or Control by:
Oct 03, 2009 | GE Ovens
Jenn-Air JGW8130A Electric Single Oven Logo
46 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
