Question about Kenmore Washing Machines
The top wont spin and the bottom will - Kenmore Washing Machines
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only
one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of
the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator
should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Posted on May 29, 2010
The middle arm on my Evolution dishwasher isn't spinning - the top and bottom one seem fine. Glasses especially on top shelf aren't getting clean at all (obviously!). Any suggestions?
Check if the holes are blocke dwith dirt the arms spin by newtons law that every action has a reaction (like a rocket) if the holes are blocked it wont spin as there is no force.
Dec 29, 2010 | Dishwashers
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Amana NAV2330 Wont Agitate or Spin
i would assume that perhaps you did not wind hte belt correctly arround the legs of the pump and therefore are not putting the correct tension on hte pulley(remember to hook spring back up to tension idler?)
Dec 08, 2008 | Roper RAS8445KQ Top Load Washer
The toppart of my adjitater wont spin around ony the bottom part does
you dont the top part spins independent of the bottom if its not working at all you can get a kit at appliances parts store to replace the dogs in it to catch when the agitator does its back stroke but its supposed to be loose
Sep 11, 2008 | Roper RAB2121KW Top Load Washer
Washing machine wont spin anymore
whirlpool made? check the coupler between motor and transmission. Open cabinet by unhooking 2 clips inside control panel and remove entire cabinet.
If its ge or maytag then check belt. Some maytag designs have the belt on bottom (below the cabinet). Other wise use paintscrapper to release 2 clips between top and front panels. front panel comes forward and unhooks from bottom.
Apr 24, 2008 | Washing Machines
Wont spin out
are the clothes out of balance? sometimes it can take quite a few trys to rebalance the load. if that is the case, it probably could use new drum springs.
Mar 05, 2008 | GE WSRE5260D Top Load Washer
My maytag top washer want spin out
Check the drain pump. It could be blocked or jammed. Remove the front panel and the pump is easy to access. There will be a hose from the bottom of the outer drum to the drain pump. Remove plug from wall socket before attempting to remove any cover.
Oct 31, 2007 | Maytag Neptune FAV6800AW Top Load Washer
KENMORE DISHWASHER
in the spinning part there are 2 holes on the bottom of it that push it to spin. if they are clogged it wont spin.
Oct 09, 2007 | Kenmore Dishwashers
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
