MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK THE WASHER WIL NOT SPIN TO REMOVE THE WATER
Moffat washing machine does not remove water after spin cycle
Posted on Aug 08, 2010
Same problem, the SPIN DOESN"T WORK to remove the water. clothes are completely soaked after drain and spin... Anyone else have any ideas. (other then the ridiculous comment provided)
Posted on Feb 13, 2011
  • spongeface Feb 14, 2011
    K, This is an easy fix, i just figured it out. I removed the drain tube off the back and noticed it was very much clogged with lint and globs of other ****. the second I cleaned it out the washer is back to working perfect! it struggles to spin cause of all the water if can't eject.
Washer not spinning laundry all the way, still very wet.
Take the old belt to an auto parts store and have them match it. Unless it some kind of special design an automotive belt should work.
Feb 02, 2016 | Speed Washing Machines
Moffat washer (mcch6110hww GE?) trips breaker shortly after start of cycle. Can this be repaired?
Sounds like your drum brake is engaging. Fixing it is fairly cheap. YouTube it and watch a few videos on how to do it if your fairly handy.
Feb 01, 2013 | Washing Machines
I just moved into an apartment equipped with a stackable moffat MCCH6110HSS washer and moffat 350A4502P547 dryer. I've discovered that the washer appears to repeat the rinse/spin cycle over and over again...
HI, I spent many years in apartment maintenance and most communities have maintenace staff to fix issues you have with their equipment,call the leasing office.The most likely cause is a bad timer.
Mar 06, 2011 | Washing Machines
Gets to final rinse e20 come up wil not empty last rinse water out of the tub i can stop it dip the water out and it will spin out
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you !!
Aug 22, 2010 | Frigidaire Affinity ATF7000E Front Load...
K5.140 makes a revving noise when releasing the
Before you do the below steps check the water supply inlet screen for obstructions where the water hose connects to the unit. If you notice debris remove and clean the screen under running water with a small NYLON brush.
The bypass unloader valve is triggering earlier than it should. You can lubricate this by adding oil to the water supply inlet (at least 3 oz.) and very briefly switching the unit on then off 0.5 seconds. Then let is sit overnight. The next day connect power briefly and again cycle the unit on then off for 0.5 seconds. Connect the water supply and then purge the water wand hose into a bucket to catch the oil before use. After this restart the unit and operate the wand trigger under full pressure at 0.5 second intervals to ;scycle the bypass / unloader valve inside the pump. This method has worked in about 95\0 % of the machines I have worked on. The oil lubricates and fattens the seals in the bypass / unloader valve. It eihter works the first time or the seals are torn in the unloader valve and must be replaced. With only 3 uses I think your pretty much in the clear and will not need new seals.
Thanks for using FixYa.
Kelly
May 16, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Will not spin and then when I try to start the cycle over all it will do is aggitate. It is also overfilling and spilling onto the floor. It is a top loading GE washer and is just over a year old.
sounds like the water level switch is not working pop the front cover off and see if the tube on the left of the tub is still hooked up. to remove front cover use a putty knife and slide between thee top and the front cover you wil feel the knife stop about two inces from each side push in on the place where it stopped and pull out on the front cover
Dec 05, 2008 | GE WBSE2090A Top Load Washer
Maytag MAV7700, Grinding and water leak
open the front with a puttyknife there are 2 clips about 4" in on each side this wil open the top so you can remove the 2 screws holding the front panel on once removed you can see the guts of the unit..Let me know if you need more help
Jan 28, 2008 | Maytag MAV7600 Top Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Leaking when entering the Rinse/spin cycle
what is happening is the pump is not pumping the water fast enough. your washer sounds like its a frididaire built washer. there should be a pause where the washer just stops and drains, then go into the spin cycle. so if there is water in the tub and the washer spins it will splash out from the top of the wash tub. you need to make sure the drain is clear, the drain hose is not blocked or kinked, and that the pump is functioning properly. your unit has a electric pump and even though you might hear it running the impellor my be damaged and able to pump the water fast enough.it could be as simple as removing the hose from the bottom of the tub that go's to the pump and removing a sock that found its way in. or just a bad pump. its a simple job to replace it.to get to the pump remove the 2 screws on the bottom of the front panel tilt the washer back a little and slide the panel down. you wil see the pump on the lower left. so check all the things i listed and you should find the problem..Id check the pump first it most likley the problem. good luck
Aug 04, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
1,935 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
