Question about Whirlpool GHW9200L Front Load Washer
Whirlpool duet ht model # GHS9200LW door latch not
Whirlpool duet ht model # GHS9200LW door will not lock. Is there manual option to close door?
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Why is my duet whirpool washer door not cycling through. It seems locked open
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism. I found this at the Appliance Guru website.
Jul 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/dL error code on...
The F/dL is shown on the display due to Door Lock Error in the washing machine.
In this problem check the Door Lock in the washing machine. Either the door is getting blocked or not getting locked or the door latch assembly is got cracked.it needs to be checked and replaced.
This will help. Good Luck.
on Mar 11, 2010 | Washing Machines
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have an F26 code and my washer won't do anything and cannot find code in the manual what does it mean? It's a whirlpool duet ht
Hi, This F26 error means "door switch error" If the door has not been opened for three consecutive cycles or the door switch is open while the door is locked for more than 5 seconds
Do the following to fix the problem:
Open and close the door
Verify CCU operation by running a Diagnostic test or any cycle
Push the door and check if its completely closed
Apr 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ht duet still getting F dl error
DL= Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
if you have done all the abovet the CCU must be bad
Aug 28, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool GHW9200L Front Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
