Question about HP Pavilion a1630n PC Desktop
My hp pavillion n1623n wont turn on it gets power but wont turn on ?
  • HP Master
  • 5,660 Answers
Cwhitfield75, it may appear that the computer is getting power, but in reality it isn't getting enough power, is my diagnosis so far.
Bad Power Supply. Weak Voltage power rail.
Computer Power Supply's put out three Voltages.
A) 3.3 Volts {Orange insulated wires)
B) 5 Volts {Red wires}
C) 12 Volts {Yellow wires}
Each Voltage produced has it's own power rail.
{The Power Supply produces one main Voltage. 12 Volts.
The other Voltages are derived from it}
Power Supply's are rated generally in Wattage. How much is the maximum Wattage they can produce.
(And at what percentage. Generally now, they try to produce at least at an 80 percent factor. 80 percent of the maximum voltage, and at a continuous delivery}
1) ALL the lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
I am not aware of a an HP Pavilion n1623n desktop computer. I do know of an HP Pavilion Media Center a1623w desktop computer.
This computer uses an Intel Pentium D 915 processor. (Dual Core)
An Intel Pentium D 915 can use up to 95 watts.
(915 is the Model Number)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Presler.22_.28dual_core.2C_65_nm.29
To summarize, you may see lights light, fans spin, and even hear the harddrive operating, but not have enough power to turn the Processor on.
With no Processor operating, the boot sector of the harddrive will not be found, and implemented. Therefore the harddrive just sits there, and spins.
http://computer.howstuffworks.com/hard-disk.htm
What causes this?
Generally, over 85 percent of computers out there are dirty inside. Inside the computer, as well as the Power Supply.
Computer unplugged from power, computer case open, and anti-static precautions observed, a can of compressed air for computers used on a regular basis as needed, could help prevent this.
The cooling hardware components, for a personal computer Power supply, are it's Heatsink's inside, as well as the fan.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
{A Heatsink is composed of a flat plate of metal, which has tall, thin, fins protruding from it.
The flat plate of the heatsink is mounted, to the object it needs to carry heat away from.
Heat is absorbed by the plate, whereby it is then absorbed by the tall thin fins. The fins radiate the heat away. The fan moves air in-between the fins, and helps carry heat away}
When the cooling components are clogged with gunk {Dirt, dust, hair, etc}, the cooling capacity drops tremendously.
Doesn't take much.
Heat = Wasted Energy
The Power Supply tries to keep up with the call for power, and eventually cannot, whereby hardware components inside the Power Supply fail.
One of the main components that usually fail, are the Electrolytic Capacitors. They are the weakest link.
Looking back at the SMPS (Switched Mode Power Supply) link I gave, you can observe the photo to the top right of the page.
There you will see that Electrolytic Capacitors are used as Filters.
They filter the incoming AC electricity (Input Stage), and the outgoing DC electricity (Output Stage) produced by the Power Supply.
You can test the Power Supply voltages, or simply replace the Power Supply with a KNOWN to be good, compatible unit for a test.
[Compatible, being;
1) The test Power Supply unit has at least the same Wattage, or more.
{300 Watts}
2) The Power Supply should be the same shape, and size, so it will fit in the computer case.
{The Form Factor of the Power Supply used in a Pavilion Media Center a1623w, is an ATX}
3) Has the correct Amount of power cables, AND the correct Kind of power cables]
You can use a Power Supply outside of the computer case for a test, but I don't recommend it.
To test the Power Supply you are testing the Voltages.
The 12 Volt is the main Voltage to be concerned with.
11 to 13 Volts is Good.
Less than 11 Volts requires obtaining a new Power Supply.
You can test with an inexpensive multimeter, or an inexpensive power supply tester.
{An inexpensive multimeter can be purchased for around $10 to $12. Auto parts stores are but one place that carries them.
An inexpensive power supply tester can be purchased for around $20.
Conclusion to follow in an added Comment.
Posted on May 29, 2010
  • 973 Answers
Your Hard Drive could be bad.
Why is my hp invent pavillion a1700n wont turn on
you need to check the power supply of the computer, it may need to replace
Dec 19, 2012 | HP Pavilion a1700n PC Desktop
Hp pavillion dv5 not booting,turns on and hangs on the hp logo. not responding to any key commands.
Mine did that but its power dvd9..something like that... but it wouldnt work... so i kept logging off then turning it off..i did that twice and it finally worked.. i wanted to watch a movie **** it!! <----yes, i know...simple but who knows... maybe it will work for you too??... i hope you get your dvd working.. :)
Dec 17, 2011 | Computers & Internet
Solution for ''hp computer a6020a wont turn on after two months packed away'' it worked fine then went away for two months and now will not turn on has power but no blue light and nothing happens all fans...
HP has been really great with my pavillion desktop and its out of warranty and they still help me with the issues and help me solve them it may take a while to get it taken care of you may have to emial back in forth to get your promblem taken care of. Here is the email support that you can try just provide the modle number and the serial number that should be located on one side of the computer or on the bottom of the tower, and Good Luck!
PAVILION_SUPPORT_EN@MAIL.SUPPORT.HP.COM
Jan 06, 2010 | HP Pavilion a6000n (882780985018) PC...
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Hp pavillion wont boot, i just get a black screen
hello
I have read your problem and I think its a sure case of gone RAM.
Replace the RAM with a new one and your system will work fine.
Thank You
Jul 11, 2009 | HP Pavilion dv9000z Notebook
Hello I have a hp pavillion a705w it wont turn on any monitors
How Would I Go About Hooking 2 Monitors Up To My a705w
Jan 18, 2009 | HP Pavilion a705w PC Desktop
Pavillion wont work with battery
First, I recommend you to try removing and reinserting the Battery when the Notebook is turned on and powered with the Power Adapter.
I recomend you to first clean the Battery Connectors by removing the Battery and use a Earbud to clean the Metal Connectors which connect to the Battery to remove any dust which is peventing from the Battery to supply the required power to the Notebook.
You can find some related topics related to troubleshooting issues related to Batteries in HP Notebooks from the links below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00485351&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can download and install HP Battery Health Check SP3229.exe and check the status of the Battery by following the instructions.
Hope this helps...
Aug 27, 2008 | HP Pavilion dv4000 Notebook
Charging issues
if you can get a hold of a 12 volt cigarrette lighter car power cord, try and see if the lapper starts then,
if it does, then the power adapter maybe bad
Feb 02, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion a1630n PC Desktop Logo
356 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
