Question about Behringer Consumer Guitar Package
Frets stick out and scrape my fingers.. making
I have recently received a Behringer Electric Strat-style guitar... it sounds good, but the big and very disturbing problem is: The frets stick out somewhat along the sides of the neck and scrape my fingers.. making them like sandpaper...do I hold Behringer responsible for this shoddy craftsmanship, and can I get them to take it and fix it?
  • Behringer Master
  • 5,603 Answers
Not likely you can get them to fix this. Either complain to the music store where you got it or use a Dremel tool to grind the ends smooth... the latter is probably the quickest thing.
Posted on May 29, 2010
WANT TO KNOW IF MY GUITAR IS A ORIGINAL
More in likely it is, although I owned one years ago that I changed the pickup in, to make a good sounding travel guitar, so you could check the wiring to see if it looks original and not tampered with?
really hope that helps?
Mar 03, 2015 | Fender 1 NEW Fender Starcaster Mini Strat...
Frets
Not on all the guitars. My advice is to play the one you are planning on purchasing before buying it.
Mar 31, 2014 | Epiphone Les Paul Studio Electric Guitar
Trying to look up serial number for 6 string electric guitar
It would help if you told us more about:
1.) What do you want to know about this guitar?
Nov 26, 2013 | Peavey Music
Hi I have an Epiphone Dove and recently some frets have "died". Meaning they are not playable, instead of clear tones it makes a buzzing sound. I can solve the issue with a capo on the forth...
You should take teh guitar to a Luthier at a guitar repair facility. Either the frets are worn (visible) or possibly the truss rod needs adjusting. Both of these need a bit of proffessional attention. It sounds like your particular condition is probably the truss rod... also are you using the CORRECT tension strings for the instrument? Wrong or worn strings can be the problem!
Apr 25, 2011 | Epiphone Dove Acoustic Guitar, Chrome...
My s5470 does not sustain well at all.also,the bridge pickup sounds ok but lacks ''attack'' in upper register.great guitar otherwise.i use a peavy 5150 60watt amp.
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks.
Apr 15, 2011 | Ibanez S5470 Prestige Electric Guitar
How to adjust the neck to make the strings nearer to the finger boards
Two ways I'm familiar with ::
1) adjust the bridge downward (I looked at the guitar on line -- couldn't tell if it has an adjustable bridge)
2) remove the cover above the nut (where the tuning keys are) -- use a wrench to turn the nut on the rod which runs thru the neck -- it doesn't take much turning of this nut to have a big effect
With either approach, the issue with adjusting the strings closer to the finger board is that too much adjustment will cause the strings to rattle on the frets.
Charlie
Jan 09, 2011 | Yamaha APX500 Acoustic Electric FM...
I have a jackson dinky DK2. what is happening is that on certain frets, like the 13th, 14th, 15th fret on the 2nd string (B string),when playing with slight drive or distortion, the note does not sound...
The frets MAY be worn or the neck truss rod MAY need adjustment, Neither of these is DIY unless yiu have experience in repoairing guitars. Since this is only on the 2nd string, inspect the frets for wear and the only DIY thing to try is to replace that string... DO that first !!!
Oct 15, 2010 | Jackson Dk2m Dinky Electric Guitar
Truss rods and dead frets- how do I adjust the guitar so the strings are close to the neck without getting dead frets?
I own an Epiphone Casino and if I needed to adjust the truss rod I would take it to a luthier (stinged instrument repair person). There is a good write up on it here. http://www.fretnotguitarrepair.com/trussrods.htm
Hope this helps.
Bob
Oct 31, 2009 | Epiphone Les Paul 100 Electric Guitar
Need a wammy bar for a V-Tone Behringer Electric Guitar
whammy bars are available at musiciansfriend.com it looks like you have a strat copy they will need to know that
Oct 11, 2009 | Behringer Consumer Guitar Package
Behringer Consumer Guitar Package Logo
57 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
