Question about NEC LT 240K Multimedia Projector
NEC LT240K projector - image now "pulses"
I originally bought my NEC lt240K as a combination business presentation/home theater projector, but in recent years it has been almost exclusively home theater. Usage has been light either way - the menu shows only 245 projector hours and 244 lamp hours of use - this is over the projector's lifetime, I have never changed the lamp. Up until this week it has worked great, but now the brightness of the image has started to "pulse" (vary over a curve in and out, as opposed to a "flicker"). Sometimes the pulse is regular (with a cycle of about once per second or two), other times it is irregular, but for all applications it is noticable and distracting/annoying. The pulse is not input-related; the default blue screen pulses even if no input is active.
If this is a lamp problem, I will probably invest in a new lamp and keep the projector because up until now I have been very happy with it. If it is more likely to be a more serious projector problem, I would rather put the bulb money toward a new projector. Can you give me any insight/advice?
Thanks.
  • don_wood830 May 29, 2010
    That's what I needed to know, thanks.
  • NEC Master
  • 11,800 Answers
The brightness of the image can oscillate from only 2 causes:
1 - the bulb is dying -  most likely - the only way you can test that is to replace the bulb and see the result.
2 - the power source is dying - this is a much more serious problem. The only way you can test that (apart from looking for defective capacitors) is to check the voltages while the projector displays a still image - the voltages should be the normal value and constant. If they aren't constant you should see a correlation between the brightness of the screen and the value of the voltage on one (or possibly more) power lines.
Posted on May 29, 2010
    President:
  • 2,923 Answers
Sounds like the projector has two problems, the lamp is starting to malfunction, and/or the LCD function and lamp luminance.
This problem can be fixed. However, this concern should be consulted to an engineer to estimate the cost of parts replacement. The consultation / parts estimation should be for free.
You may also check for the available drivers and that might help as well.
Thank you and good luck!
Nec lt240 fan
the color wheel is broken, you need a new one. USD75
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Mar 02, 2014 | NEC LT240K DLP Projector
Wont light or turn on
1,whether the lamp is ok? -put this lamp to another projector to check it
2,whether the lamp ballast is ok ?
Have a good day!
Feb 26, 2014 | NEC Vt 695 Home Theater Projector 220 Lamp...
Panasonic vertical color lines
It seems that the lcd panels are failed
Have a nice day!
Jerry
Lampdeng Limited
Jan 07, 2014 | NEC Office Equipment & Supplies
InFocus IN72 Multimedia Projector can't handle a bright colour.
I have the perfect example for you as to why this happens. It is a bit baffling at first but once you think about it it really does make a lot of sense.
IN72 is a great projector. They've bettered the technology with newer technology preventing previous complaints from consumers..which keep in mind its a home theater projector primarily. It's also a great price for what it is which is a huge thing for consumers over the years.
The thing with a home theater pj [pj=projctor] vs.a business one is that the home theater has a lower lumens and a higher contrast ratio to them. However, when you go on the business side it's the complete opposite. The idea on this is, for example:
Conference room: Some ambient light present. Maybe lights unable to dim? Want to show mostly text. Great, business projector is the best solution unless you have a demand for a special connection that only the home theater offers then in that case you might have to go with more of a plasma, or LCD panel instead?
Home/game room combo: Controlled lighting. Great. Has blinds for example. You want to watch it for occasional tv football games, or mostly movies since you would like to have movie nights at your own home vs. going out to a theater? Well then, a home theater projector is ultimately the best solution for this situation.
Why do these situations not want to combine?
Simple actually.
Lumens=how bright the projector is
Contrast ration/ratio: the rating in which compares the black levels vs. lights in a pj
business: brighter for people to read text unless you are using it for video/color purposes.
Home: less brighter but have awesome blacks/whites which people WANT for home theater.
What I'm getting to with this....
When you have a home theater project you do not want any light but maybe a soft light in the room. The projector has this path of which it projects this bright image into your screen. Any lighting passing through that will break it up and make it less. The perfect way to imagine this is get a flash light. You can see it very well with the light off. Perfect, huh? You can see where you are going. Well, when you turn the light on it breaks up the lumens in the flashlight and you can not see it very well if at all.
So any light in your room will desperately influence the picture/image you will get off of the projector. That is why you are seeing the image become more distorted.
If you're going to use this under a well light situation either a super large plasma is ideal to maintain brightness otherwise a bit more expensive higher lumen pj to fix the solution a little bit. You can change all the settings you want, it might make it a bit more brighter which will run out the life of your lamp even quicklier, but there is only so much you can do but change the location of the setting/environment in which it projects.
I'm sure this is a lot of information. Let me know if you have any further questions. Thank you for your time and I wish you the best of luck.
Sep 26, 2008 | InFocus ScreenPlay 4805 Multimedia...
NEC LT240K remote stops working while in use
clean it out. alot of times dust will block the sensors.
Jul 28, 2008 | Office Equipment & Supplies
NEC Overhead Projector
Hi Forrest
This sounds like a damaged Mainboard.
First check if your Projector is still under warranty as this is a very expensive part to have replaced.
Also check if it has any effect whatsoever using another PC Cable.
Hope this is of help.
Mar 29, 2008 | NEC VT47 Multimedia Projector
No Image nec vt465 and yamaha rx v540
You must use the projectors menu to choose the type of input for video out. Your projector is capable of 720p or 1080i high def, but not through s video. If you want high def you must use the component output from your receiver to input on your projector. I hope this helps.
Jan 23, 2008 | Audio Players & Recorders
NEC LT 240K Multimedia Projector Logo
120 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
