Question about Yamaha RX-V2600 Receiver
HTMI errors on the following devices DVD Blue-ray HDMI connected; CD Not HDMI connected; VCR Not HDMI connected; satellite works OK HDMI to Yamaha - HDMI to TV NO HDMI error displayed; GUI does not display on TV screne - all black screen, disconnected power and HDMI cables on all units 20 minutes - no change.
    President:
  • Yamaha Master
  • 1,114 Answers
You have to use Component Video on this unit. HDMI will not "Handshake" and pass thru. This was HDMI's first version "1.1a" and there is no fix. Use your receiver to switch audio via Coaxial or optical then use HDMI directly from BLURAY etc to your TV. The downside to this is how many HDMI inputs your TV has. It's an awesome receiver! Don't blame Yamaha!!! This issue is directly attributable to "HDMI" and their race to shelves before truly field testing the product. The current version of HDMI is 1.3b and soon to be 1.4 which includes ethernet capabilities.
I hate to be the bearer of bad news! If you would like an "in depth" look into the world of HDMI issues, Google HDMI problems or HDMI forums, and you can read for hours. Hope this helps
Posted on Jun 03, 2010
    Master:
  • 708 Answers
You have to use Component Video on this unit. HDMI will not "Handshake" and pass thru. This was HDMI's first version "1.1a" and there is no fix.there are more details about it,pls check
Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
Posted on Dec 16, 2016
How to repair HTMI port "no signal" on screen
Just pull out the socket to the port, and fix an other in that place. It will come out easily as you pull out, and can be fixed a new one for just one hard push.
Sep 26, 2016 | RCA Televison & Video
Panasonic how to connect
Good day
The best option would be to connect a HTMI cable to both devices. There is only one HTMI out on the Blu-ray and 2 inputs on the TV. Any one of the 2 on the TV will work. Than select the source on the TV to reflect the HTMI selected
Jan 30, 2014 | Televison & Video
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
We have a Samsung Smart TV. We cannot get the signal and have installed a Digital Satellite Receiver. We have a Magnavox VCR and a sony DVD Player. We owuld like to attache the same to our TV and watch...
Depending on your Satellite receiver's output type (i.e. HDMI or Component - Red, Green, Blue) you should connect to your tv's appropriate external inputs. Example: if you choose to connect the receiver via HDMI, then you use the SOURCE button on your tv and select the correct HDMI input you have connected your device to. If connected by Component (Red, Green, Blue) then use the SOURCE button to select the correct Component input, and so on.
Note: HDMI is the best connection type - you won't be able to access your receiver from the tv's built in tuner.
As above explanation, your VCR and DVD devices should be connected to your tv in the same manner - unless it is a combo unit (VCR & DVD in one), in which case this device can be tuned into your chosen tv channel (via the tv's tuner).
Note: if you have one of the latest SMART tv's, it should already have a built-in "Hi Definition" tuner which will allow you to watch free digital tv broadcast (DVB).
Hope this helps...
"Please rate this solution"
Aug 28, 2011 | Samsung Televison & Video
Vcr tape . does not record to dvd-r disc Using hdmi cable from TV to recorder.
It is a HDMI OUT on the DVD/VCR Recorder.
You can only record to a DVD/VCR from the External DVD/VCR Input (Connected to a Freeview, Cable or Satellite Box etc) or from one to the other.
Jun 09, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
How to perform a master reset
Unhook all HDMI connections unplug the yamaha and your tv from the wall outlet then try again. Most cases a copy protection kicked in or the hdmi had a error on the port, Worse case is hdmi controller board failure in ether the TV or the yamaha.
thanks and do be considerate and leave postive feedback and ratings for those that have helped you today, Thanks
May 29, 2010 | Yamaha RX-V2600 Receiver
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Yamaha RX-V2600 Receiver Logo
1,118 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
