Wasing machine stopped begore end of spin cycle half full of water
  • 159 Answers
I dont know what type of machine you have.
It sounds like the pump is the cause of the problem,it has stopped pumping the water.its probably blocked with debris.
Posted on May 29, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
My miele wt945s takes in some water after final spin so clothes at bottom of the drum end up wet. Can I stop this happening
There is a problem with the programming of the control board if this is occurring.
All you can do is turn off the water to the machine at the end of the full cycle and then run the spin cycle again to dry out the clothes. Then no water can enter the wash drum.
Otherwise you would need to turn off the water each time before the spin cycle concluded and thus before the machine began adding water again.
Dec 08, 2015 | Miele Washing Machines
Malber P28 washer. On hot water cycle the drum is part filling with water then stopping wash cycle and door is unlocking. I was able to open the front loading door with the drum half full of water - gushed...
Sounds like a control pcb malfunction. Remember that you are dealing with MAINS Voltages which can be lethal.
Never continue to use a machine that floods or enables random water release for any reason. The end result might be Electrocution, and it is certainly not worth that risk
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Malber P28 Front Load All-in-One Washer /...
Wasing machine stops spinning during final spin - 3 or 4 minutes into the cycle.Frigideaire front end loading washing machine.
You could be using too much soap that will cause the machine to go in oversuds motor protect and shut down . Do make sure you are using HE soap and only about 2 to 3 table spoons per load .The next most likely cause would be the door lock but I think you have a soap problem..Good luck need more help please ask Thanks for Voting
Mar 13, 2011 | Frigidaire ATF6000ES Front Load Washer
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Water overflowing from Wasing Machine AAV7000AWW Admiral
this is 1 of 2 problems. either the pressure switch is no good or the pressure switch hose has a hole in it causing the air pressure from triggering the switch. locate the pressure switch and pull the hose off the end. start the washer and try to blow into the end where the hose was connected. if the water stops then you will need to replace the pressure switch hose. if the water doesn't stop coming in then you will need to replace the pressure switch
Jan 01, 2009 | Admiral AAV7000A
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
