How do I open the control panel to check the wiring which you told me to do yesterday? Which tool also? Model number GHW9300PW4 thx
  • vegasdvm May 29, 2010
    I need more assistance
    Brigadier General:
  • 3,917 Answers
HI,
Please find the detailed steps of opening the control panel in your washig machine in the following article.
http://www.ehow.com/how_5767360_open-control-panel-kenmore-washer.html
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on May 29, 2010
    The model number is HW9300PW4 Serial # CST2218039. THe last Kenmore/Whirlpool booklet did not show for my washer.
My Whirlpool Duet washer is only using with hot water regardless the temp setting then errors out 5 minutes in with F 05. Is there any way I can test the temp control or control board?
Since you checked or replaced the parts that are most causes of the failure, the control board is most suspect. Make sure all the wiring involved is securely connected to the board and devices. I don't know how to specifically check the board inputs but usually the board gets replaced when the other suspect devices are working.
Dec 27, 2016 | Whirlpool Washing Machines
Kuds24se dead
HAve you check the power supply to the control panel? you may need to open the panel and check the circuit.
Sep 18, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
LCD TV no picture
send a email with your model number and what your needing to sonny@tvcircuitboards.com he should be able to assist you.
Jul 09, 2012 | Vizio L42HDTV 42 in. LCD Television
I have a whirlpool GHW9300PW4 that keeps flashing F-06
hi janice f06 means The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness hope it helps
regards
shaun
Nov 10, 2011 | Washing Machines
I got a new affinity washer yesterday and when i tried to wash clothes it keeps saying pause. Then i get an error code of 41. please help model number is FAFW3801LW
this means the control board thinks the door is open check the wiring to the control board and the door switch make sure everything is connected properly
Jan 16, 2011 | Washing Machines
How do i fix the toshiba satellite u305 s5077 no sound problem on windows 7
hi
simply went into my Control Panel, switched to Classic View, and opened the Device Manager. Then I opened the Sound folder, clicked on the Realtek and told it to DISABLE, then ENABLE
THX,
Banaple
Sep 02, 2010 | Computers & Internet
Duotherm sunchaser compressor wont kick in today-worked yesterday
CHECK YOU RUN CAPISITOR ON THE ROOF YOU WILL HAVE TO REMOVE THE COVER ON THE ROOF THERE WILL BE A ACESS PANEL USUALLY THE MODEL NUMBER AND SERIAL NUMBER ARE ON A STICKER ON THE ACESS PANEL REMOVE PANEL LOOK INSIDE YOU WILL SEE TWO CYLINDRICAL LOOKING TUBE DEALS WITH A BUNCH OF WIRES WITH SPADE TEMINALS ON TOP OF THEM DO NOT TOUNH THESE WITH AND PART OF YOUR BODY OR TOOLS !!!!!!!! JUST LOOK AND SEE IF ONE IS SWOLLEN OR MELTED IF SO UNPLUG THE UNIT FROM SHORE POWER AND VERY CAREFULLY REMOVE THE MELTED OR SWOLLEN CAPISTOR GET A DIRECT REPLACEMENT NOT ATER MARKET AND REPLACE TAKING CAREFUL NOT OF WIRE PLACEMENT IF THIS DOS NOPT SO0LVE PROBLEM GET TO A QUALIFIED SWERVICE CENTER AS THERE IS NOTHING ELSE A CONSUMER SHOULD TOUCH AFTER THAT
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
Machine won't turn on flashes dL F code and gives me short buzzes
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool Washing Machines
Hi, I have a KitchenAidDishwasher (Model KUDP01FL). It's worked well for a few years. Yesterday, when we went to turn it on, none of the lights on the buttons were on. WE can't turn it on at all. The...
Kill the power to the unit. Pull the control panel down to access the control board located on the right hand side of the panel. There will be 2 wires coming in to a white plastic clip on fuse located on the side of the control board. It will have a plastic pliable shield over it. Pull the 2 wires and check for continuity across this fuse. If no continuity then go to parts house with model number of unit and ask for thermal fuse for your unit. Replace this fuse following the instructions included in the kit and use all the parts included in the kit.
Apr 11, 2009 | Dishwashers
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
