Question about Philips 30PF9946 30 in. HD-Ready Plasma Television
No picture, but we do have sound
The television switches on alright, but we only get the sound and no picture
I had the same issue. I took it to a local repair guy and he repaired it for me for $98. The soldering on the inverter board is what is creating the issue. In some cases they can re-solder it and be done or in other cases need to replace the inverter board. It's not that expensive to fix.
Posted on Jan 19, 2011
My Avis flat screen HD TV has sound but no picture.
First thing to try is if using a box for signal unplug both that and the set from power for several minutes and then plug back, it is possible the issue will be gone and the set working normal again.
Dec 05, 2012 | Televison & Video
No picture no sound
go to ebay and search for TEXAS TV PARTS or texasgreatdeals4you.
then Ask this guy to fix your board,he will tell you which board to send to them.
alright.
Jul 07, 2012 | Toshiba 42H81 42" Rear Projection...
Bought the A99HR Nikkai DVD player and recently the sound does not work anymore. Picture and everything else is working alright.
I had the same problem when I switched over to a HDMI cable. It's the sound settings. I had to switch my audio setup in the settings menu to PCM for HDMI and also choose only SPDIF / RAW or PCM.
Jun 13, 2011 | Audio Players & Recorders
No picture on my mitsubishi wd73c9
If you have sound on your television but no picture, then you need to understand that the t-con board of your television is bad and need to be replaced. The t-con board is in the upper middle part of the main board of the television. Once you replace it, the television will be alright once again.
Hope this helped.
Take care and good luck
Jan 10, 2011 | Televison & Video
NO PICTURE OR NO SOUND it just black
power supply not working -- did you check internal fuses on board --? if everything checks alright - replace the power supply board
Mar 02, 2009 | Televison & Video
Rca hctv
Good Day;
I would suspect the fuse near the IHVT, conv. power board or conv board itself. check voltages going to the convergence board. Good Luck, big IRISH.
Nov 15, 2008 | RCA HD52W59 HDTV Projection Television
When i switch my samsung lcd tv model le32r87bd it starts alright but after about 2 seconds the picture goes and the screen turns black i can still hear the sound and the remote seems to still work but no...
Sounds like you need an inverter board which is the power supply for the screen lights. I tried to look up the part but samsung dosen't have a service diagram posted for it yet. Since it is so new you may want to find a samsung authorized service center because if the part is not available yet Samsung will have to solve the problem.
Jun 27, 2008 | Samsung Televison & Video
TV
We have perfect picture but no sound when changing channel you get a sharp noise and thats it 1 reset once 2 ptoblem in transmission 3 as noise is there so your audio section is alright. the problem is sound signal in not reaching to audio section or print break in that line or some one has mistunned sound if section coil. hope this will help.
Oct 03, 2007 | Televison & Video
Open Questions:
HDMI quit working I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent problems with the HDMI audio bleeding in to the other inputs. Sometimes if for instance I turned on the PC, I could hear the audio from the HDMI output on the satellite receiver through the TV speakers. Other times, I might just hear a crackle in the audio when in PC mode. If I switched back and forth between HDMI and PC inputs a couple of times, both issues would go away. I tell this just as background to what happened next. Since I have my PC hooked to the VGA input on the TV, I have been forced to manually switch the HDMI input from the Satellite receiver to my XBOX 360. (Sorry, I was too cheap to buy the $100 switch). Anyway, I usuall make this switch hot (TV on, Satellite receiver on, but XBOX off. This system although a pain, was working until yesterday. I was watching HD satellite, when I decided to play XBOX. I switched the HDMI cable, but when I turned the XBOX on, it wouldn't start up. I immediately assumed my XBOX had crapped out , but when I switche the HDMI cable back to the satellite, the TV would not recognize the signal. I have since tried the XBOX and satellite on another tv with HDMI, and both still work fine. I am thinking that some sort of switch in the tv has gone out, but I don't know. Should I just junk this TV for a new 1080P? My problem with doing that is that I use PIP with the PC on one side, and HDMI on the other. This tv does that, but I can't find another tv that does.
Feb 28, 2017 | Philips 30PF9946 30 in. HD-Ready Plasma...
Philips 30PF9946 30 in. HD-Ready Plasma Television Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
