Question about Kitchen Ranges
I get an error code on my Whirlpool RF362BXKW range. I have shut down the power to the unit, have cleaned the unit and the error code won't go away. None of the oven cooking options work with the error. The error code is FSE1 or F5E1
  • 1 more comment
  • christineboc Nov 20, 2008
    I have tried to turn on the slef cleaning button for the oven and it sits for a few minutes reading 3:30 and starts to beep and the F5E1 error code pops up on the time display. It will not go into the self cleaning mode.
  • khouse01 Mar 28, 2009
    This happened to me also right after doing a self cleaning. Sounds like a recall issue whereas the self cleaning oven is getting too hot and burning the switch.
  • Anonymous Mar 30, 2014
    Have cut the power to it - did no good.
What I did was hit cancel and hit the unlock button. Then I leaned against the door a bit as I hit the lock and hit the self clean and start the lock check dissapeared. I hit lock again and nothing else and it started the cleaning process.
Posted on Apr 13, 2010
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
F5 E1 Solenoid/motor not
operating or latch
switch failure
1. If door latched:
A) Disconnect power from unit.
B) Check wires and connectors from control to door switch, then from door switch to
control. If no damage found, proceed to step C.
C) Replace door switch.
D) Reapply power to unit for more than 1 minute and verify operation.
2. If door not latched:
B) Check wires and connectors from control to latch switch, then from latch switch to
C) Repeat steps A) and B) for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed).
5. If corrections are made in any step, reconnect power and verify correction.
6. If failure remains, disconnect power, replace control.
Posted on Apr 08, 2008
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
The Oven and Range are working; however I have a F5 code on the display. Can you tell me what this means?
The F5 code means that the range door isn't latching properly (for some Whirlpool ranges). Check the latch when the oven is cool. If it is loose, tighten the screws that hold the latch. Try opening and closing the door to see if the latch is clicking shut properly. Then unplug the range for 30 seconds to a minute to reset the unit. If the error clears, you're done.
If the error persists, clean the latch area. With the oven not in use, rub the latch area with a cloth that you dunked in hot water and wrung out the excess water. Then dry with a paper towel.
If cleaning doesn't help, the latch probably needs to be replaced.
I hope this helps. Please give me the model number of your range for additional ideas. Whirlpool has the user's manuals for most of their appliances at their site. See http://www.whirlpool.com/custserv/index.jsp and the Manuals and Literature search box.
Jun 06, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Won't self clean. I am getting an error messag FSE 1.
Most likely it is F5-E1 code. self clean latch will not lock. follow procdures below,but likely problem is failed lock motor
All F5-E Codes - Door Switch Defect - This occurs when the door switches do not match. If door is latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, reconnect power and hold down any key until the F5 error clears. Once the F2 code appears, select 'cancel' and observe for one minute for errors. If door is NOT latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, measure door switch (door open = latch open) and latch switch (unlatch = switch open) and replace either if defective. If corrections are made during any step, power should be reconnected and the unit should be tested. Press and hold any key to clear the error code and F2 code should appear. Select 'cancel' and observe for one minute for errors. If error continues, disconnect power and replace control.
Dec 28, 2010 | Whirlpool GR460 Electric Kitchen Range
Oven won't light and the display is flashing E1 F1
HI. This is essentially a board code(EEPROM check-sum error). Use this check procedure to confirm failure.
1. Safely disconnect the power from the affected unit for five minutes.(Shut of the appropriate circuit breaker or unplug from the wall)
2. Re-apply power and observe for at least one minute.
3. If the code re-appears, replace the main control board (also called ERC or clock).
Jul 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven won't lock shut for cleaning
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My range whirlpool gs445lems gets an error code of e1 f2 shortly after turning it on and it shuts down. what do those codes mean?
Unfortunately, this has happened to us twice and both times we have had to replace the contro panel to the tune of almost $200.
My husband thinks it's because it gtes fried when using the self-clean option. We hand-clean now.
Dec 02, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Dec 18, 2008 | Kitchen Ranges
I have a whirlpool self cleaning oven and have an error code F1 E2
Hi Headcl
F1 E2 fault code is an error on the control board of the stove. By disconnecting the power from the unit for about 0.5 to 1 minute and then reconnecting the fault may go away after a minute or two (reset). Otherwise the clock (ERC) has to be replaced.
Regards
Nov 16, 2008 | Maytag Kitchen Ranges
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Kitchen Ranges Logo
1,357 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
