Question about Edu-Science (10166) Telescope
One ofThe plastic top part at the end of the leg the one that as a black hook is brooken i wonder if i can have it ship it as 2 littles scroos i live in montreal canada there is a toys a rus not far from my home ps is a astro-nova 100
  • 3,186 Answers
Maybe, contact Toys R Us
Posted on Jun 01, 2010
In onida tv d2498 and fuse in power supply gone on connecting ac.Without main board installing please help
If it's not the main board that's causing the fuse to blow then you have a short circuit somewhere in the power supply. Check things like the electrolytic capacitors. The ones that look like little cans. They should all have flat tops. If any are bulging out at the top they will need replacing. Also check the bridge rectifier which is a black component usually standing up on the board with four legs. If there is no bridge rectifier there will be 4 rectifier diodes together. They are black cylindrical items with a sliver band on one end and a lead out of each end. They are usually located near to where the mains lead enters the power board. Other things to check are power transistors, they are usually 3 legged, (sometimes 2 legs if they are used as a diode) black items with their case fixed to a heat sink (aluminium block.)
Dec 15, 2014 | Televison & Video
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
Washer spins but it makes a bumping noise
Try to rotate the drum when it is not in use, manually and see if you notice the sound as well. If you do the drum is not balanced and you would need a professional technician to diagnose the bearing and pulley system behind the drum for repairs.
Sep 23, 2012 | Frigidaire ATF6000ES Front Load Washer
How to disassemble a Keurig B60?
Not sure why you want to get the top off first :(
start with the black wrap around shroud first...
Take the metal bottom plate off first... then you can see the way the wrap around plastic shroud slides off... however... you have a hose and water tank plate base assembly in the way... need to cut the ty-raps off the hoses... they are smaller then 4" Panduit ty-raps... so go get a few... only 2 or three.
Once toy get that water base unit away... watch those leds...
you start from the right side of the shroud and pull the shroud down... exposing a phillips screw on top... get needle nose pliers to start a bite in it.
the shroud has self locking plastic teeth molded on the shroud and the silver top...once snalled onto place, they are a bytch to get off.
I wrote instructions to do this on another question... work carefully... use a stiff pointed piece of plastic shaped like a chisel... metal will chew up the plastic cover and shroud.
there are 2 screws... one on the left one... one on the right... start right side first
May 15, 2010 | Keurig B60 Coffee Maker
Leeks coffee into grounds container
HI
You have a stripped thumbscrew. Check the top left side of the brew unit. The thumbscrew is the little rod that sticks out of the top of the center part of the brew head. If there is water in the center cavity that's your problem. If you push down on the rod and check your brerw head screen on the other end it is probably pushed out a little. Pry the screen out, and you should see a barrel nut in the middle of the screw stem. Pull the thumbscrew out from the other end.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item about that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Nov 17, 2009 | Saeco Magic De Luxe Espresso Machine
LD-14AW2 door hinge support broken
They are at the sides and back 2 slots to the levers . Vitally
May 12, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Need to know where do i have to hang the 2 resources that are on the side door
I believe the 2 springs hold your side door closed, alot of people use scotch tape to hold the door closed.
Anyway 1 goes on the left side and the other goes on the right side of the door. If you open the door and look down on the plastic frame, not part of the door, you'll see 2 holes on the left and 2 more on the right. The one end of the spring slide down thru the 1 hole and turn it 90 degrees and pull it up so it hooks on the plastic piece between the 2 hloes. Do the same for th other side. Now, the top end of the spring attaches to a plastic tab in line with the holes on the door, toward the top side. Some times those tabs break off.
If that's the case we'll have to get a little creative
Good Luck
Bob
Apr 17, 2009 | Canon NP 7130 Black and White Copier
Sony Grand WEGA 60" LCD TV Problem
TO FIND YOUR THERMAL FUSE ITS LOCATED ON TOP OF THE LAMP FAN HOUSING SHOULD BE 2 BLACK WIRES RUNNING TO IT IT'LL HAVE A LITTLE BLACK SQUARE ON THE END OF IT THATS YOUR THERMAL FUSE
Jan 06, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Mutsy Urban Rider
Hi guys, I had this problem when I first got my urban rider - the trick is to put the seat on correctly in the first place. If you look under the front of the seat (when seat is facing away from mum/dad) you'll see 2 plastic hooks - these need to be hooked over the first horizontal bar of three that you can see (it has a small black plastic nobbly bit on it) then, as you were doing, push the handle and pull the 'tube'. If the seat is facing you (child travelling backwards) it won't fold, neither will it fold with the carry cot attached.
Hope this helps! Tegans mum x
Feb 14, 2008 | Mutsy 4Rider - Pink Stroller Frame
Edu-Science (10166) Telescope Logo
163 people viewed this question
Top Edu-Science Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
bobalix
Ted Maxwell
Are you an Edu-Science Optic Expert? Answer questions, earn points and help others
