Question about LG Flatron L1751S-SN 17" Flat Panel LCD Monitor
What is the best way to clean the screen of a
What is a safe, easy way to clean the screen of a LG Flatron lcd monitor.
And why doesn't LG have a standard tested answer to a simple question like this.
  • 466 Answers
It depends on the kind of dirt you've got on the LCD screen.
Dust and fingerprints may be safely removed using a tissue-non-tissue or microfiber cloth, sold in most camera shops. It's exactly the same supplied with most glasses, only bigger. It works without moistening. Do not press overmuch, but wipe it repeatedly, and even the sturdier fingerprint WILL come away eventually.
There are also specially formulated moist-wipes. They're more expensive and only good for one use each, but are good to clean dried spills such as specks of sugared coffee or an explode-on-open Coca Cola can. You'll find them in most computer shops.
Posted on May 29, 2010
I need the drivers of flatron w1943tb....
LG Flatron L1515S doesn't need a driver to be installed on Windows Computer or any other systems. If you have problem with it, then it should be your graphics driver that you would need to install.
Similarly W1943TB-PF doesn't need driver. (I am not sure which one among the two LG Flatrons you have since your question is tagged under the LG Flatron L1515S while your problem refers to LG Flatron W1943TB.
If you have other problem, let me know with more details.
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | LG Flatron L1515S 15" LCD Monitor
All white screen
tried to replace the vga cable and fix the vga port doesn't work?.if still white screen the cause will be bad lcd controller.
Oct 27, 2012 | LG Flatron L1710S 17" LCD Monitor
Screen doesn't want to come on, then goes dim
The problem is caused by one of the inverter transformers, or one of the backlights behind the LCD screen is going.
Jun 02, 2012 | LG 22" FLATRON LCD Monitor
Which is the best screen resolution for lg flatron l177wsb with a windows 7
According to LG's webpage on that particular L177 series of monitors, its maximum resolution is 1440x900. Hence, you can have max resolution of 1440x900, which is off course the best available with this LCD.
For more info you can visit manufacturer's Link
CreativeTECH
Jan 22, 2011 | LG Flatron L1750S 17" LCD Monitor
How do I clean my flatron E2350V monitor
Any glass cleaner without Amonia, I use screen cleaner from Radio Shack, apply it to the micro fibre cloth and wipe the screen gently.
http://s807.photobucket.com/home/budm/allalbums
Jun 06, 2010 | LG Flatron L1919S LCD Monitor
I am using the LG Flatron L1715S 17" LCD Monitor as an external monitor for my lap top as the screen on my lap top is toast. What I cant figure out is how to size the screen to fit the proper dimensions of...
The FLATRON L1715S color LCD monitor with auto-synchronous support, plus it is PC and MAC compatible, has features like simple one button auto setup and is VESA DDC2B, DDC1, Plug and Play compatible.
use the 'Auto' adjust button on ur lcd..
howevr, if u want to configure using win xp/vista..right click on ur desktop->properties->settings->increase the 'screen resolution' to minimum: 640x350 or standard: 1152x864 or maximum: 1280x1024 @ 75Hz..
best is to seek professional advice of ur system admin/vendor....
Nov 05, 2009 | LG Flatron L1715S 17" LCD Monitor
Brand New LG Computer Monitor Flickers/Goes Into Power Save Mode
well right click on your desktop and goto properties and then goto screen saver and then goto power and then on the monitor setting goto never.
Sep 20, 2009 | LG Flatron L2320A 23" LCD Monitor
Black screen on my LG Flatron lcd 563le
I solved the problem myself by disconnecting the monitor from the computer and then I unplugged the computer. I restarted the computer in position fail safe (F8) and tried to change the monitors resolution back to origin, failed to do so and rebooted instead. When Windows loaded up the problem was gone! Yipeyiiiii!
Bjorn
Jun 02, 2009 | LG Flatron 563LE 15.1" LCD Monitor
MOISTURE OR DAMPNESS ON lcd SCREEN
This is what happens when you use a spray glass cleaner on an LCD monitor. The spray gets into the edges of the plastic and eventually behing the mylar screen. There's no safe way to clean it that I know of. Ta
Mar 13, 2009 | LG Flatron L1718S LCD Monitor
What is the best method for cleanig a flatron
Take a clean cloth and spray some windex on the cloth and then wipe down the screen and it should come nice and clean. Never spray it directly on the screen cause if the liquid goes down inside of the screen then it could damage it.
Mar 01, 2009 | LG 22" FLATRON LCD Monitor
LG Flatron L1751S-SN 17" Flat Panel LCD Monitor Logo
126 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
