Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Need to know how to tighten up the steel deck on our Poulan.
The deck seems to wobble more than it should and it shows it on the lawn by cutting deeper on one side then on the other as you cut the grass. I just want to know the proper way to tighten it up.
  • 66 Answers
Sounds like you have a broken or unattached leakage that supports the deck. Check first to see that there all hooked correctly. If so...you can adjust with some by tightening the bolts on the supports. www.nnyparts.com
Posted on May 30, 2010
What is the diagram for steel deck installation for a poulan lawn tractor 42 " deck 14.5 hp ?
Do a search on goggle for the make model and deck size and you can see the routing diagram.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Need to fine out if it would what other size of belt you can use on 38 inch cut on poulan riding lawn mower
Are you asking what size belt to use or are you asking what other size belt, like you want to use one a little smaller or a little larger? If that is the case, what difficulty are you having that you would need to do that? Did you put a Craftsman deck on a Poulan or something odd like that?
Aug 06, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
The mower is not cutting even. we changed the blades and leveled the deck but can not seem to fix the problem
Everything sounds and looks good but the cut is uneven. I would think the only possibilities are a freewheeling blade, or an upside down blade. Neither situation is rare. If neither of those is possible I think I would set the whole thing up on jack stands and make sure nothing is going akilter in the mechanism which raises and lowers the deck, one side could be hung up.
Aug 04, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Toro workhorse rider leaks oil
what bolts are you tightening if it is the bolts going up from the inside the deck then you are tightening the wrong ones they are sitting on top of the deck under engine the bolts under deck need to be taken out motor taken off then tighten crank case bolts to stop leak
Jun 22, 2010 | Poulan "Poulan" Push Mower
Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How do you remove the rear wheel to fix flat tire?
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
May 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan riding lawn mower starts but won't shift into any gears
your cluch is not disengaging when you step on the pedal check ajustment on cable tighten cable and try again...good luck
Apr 10, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan PO175H42STB lawn mower operator's manual
Check searsparts.com web site type in your model you can most likely get what you want
May 06, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
80 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
