Question about Goodman CKL42AR42 Air Conditioner
Inside fan not turning on, outside unit is turning on
Fuse is ok, fan motor does get power but does not turn on
  • 674 Answers
First turn the power off and see if the fan is rotates freely. Turn it by the shaft and not the fan blades. Its easier to feel the resistance. Next check you capacitor. If that's good then check the fan windings for continuity.
Posted on May 29, 2010
I have a Goodman CPLE30-1A outside unit and the fan stop spinning. The fan stop spinning so I turn off the main power to the unit and I can spin the fan with the power turn off so I'm not sure if its...
Hello
There are a few things here that could be wrong.
1 Fan motor start capacitor is bad.Silver battery looking device on side of fan.Remove and replace with a new one.
2 Contactor for fan motor is pitted or burnt .If this is the case you will need a new contactor.
3 Fan motor is bad.Check top two before assuming this.
Check all fuses and circut breakers also.
Aug 29, 2011 | Goodman CKL42AR42 Air Conditioner
Outside unit is not turning on but the inside unit is
I would check the fuses or breaker to the outside unit.
If nothing (either the fan motor or the compressor) is running - chances are you have no power to the outside unit.
It's also possible that your low voltage wire from the inside t-stat has been 'cut' or 'chewed into' (by a dog), but my guess is the fuses/breaker.
Jun 05, 2011 | Heating & Cooling
Rudd central unit , turn A/C on[therm. inside] all U can hear is a Buzzing noise coming from the outside unit , found that [1] capacitor wire had been BURNT , changed wire , then changed capacitor , turned...
Hello
Before you buy a new condensor fan motor check the contacts to the motor are not worn or pitted.
Hold or push the contactor in by using an insulated screwdriver and see if the fan motor turns.
Also the start cap you bought? was it the correct one meaning mfd micrfarad?
If all the above checks out ok then you need a fan motor,you can wire the motor direct to check it also.
From what you describe it sounds like the fan motor is burnt up and worn out,not uncommon.
Mar 22, 2011 | Heating & Cooling
Outside unit won't turn on inside unit turns on
check the mode is on cool ? then check the signal at the outside terminal if ok and the fan motor is on open the compressor terminal check voltage if ok replace capacitor
Sep 07, 2009 | Heating & Cooling
Nordyne AC unit works at first but later provided cool air. Thermostat set to 65. Power running to unit outside. Noticed ice around line outside and can send a picture. Chipped ice away. Want to know what...
If the inside fan motor is running OK you are low on refrigerant. If the inside fan motor is not running, repair the inside fan motor. Could also possibly be dirty inside coils.
Jul 20, 2009 | Heating & Cooling
My home air conditoning compresor doesn't always come on.
All timers are located on the main control board in the air handler " inside unit ". There is a circuit board in it near the heat strips and it has a couple of relays that are notorius for going out. Replace the board and the condenser unit " outside unit " should start to operate properly.
Jul 07, 2009 | Heating & Cooling
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
What are the major reasons that my fan doesn't turn on on my central air conditioning unit?
wire,fan motor or capacitor.If the compressor runs its prolly not the capacitor.If it doesnt,may also be the contactor.
Aug 19, 2008 | Heating & Cooling
I have a colman ac unit and the outside unit will not come on. i hear it clicking but nothing happens
On my computer screen these two problems are not the same.
To "garys2003" Clicking you hear is the contactor closing in calling for cooling. If no power is being supplied to the outside unit high voltage the unit will not run. Check your circuit breaker or fuses in the outside power box. If the outside power box is of the non-fused disconnect, check that the disconnect is inserted properly.
To Trenina: Is your unit a self contained unit outside ducted to the inside as with a Mobile Home. If so your evaporator cooling coil may be frozen over stopping air movement, turn the cooling off and set your fan to on until it defrosts, then return to normal operation and leave the fan on during cooling.
If nothing comes on inside as with a central A/C system you may have a problem with the blower motor itself.
May 12, 2008 | Heating & Cooling
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
128 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
