Question about GE Profile PSS26NGS Side by Side Refrigerator
The refrigerator is leaking from underneath the machine , what might sbe causing this?
    Scholar:
  • 59 Answers
In the freezer section. Behind the lower rear wall is the coils and just below that is a drain. If you will remove any ice and use a coat hanger or screw driver to push down through that hole you should be able to get it unclogged. Take a small cup of water to verify that you have it unstopped and your done.
#225 in the drawing.
Posted on May 29, 2010
Why is water leaking from inside?
If your refrigerator has automatic defrost, condensate drains to the bottom, then through a plastic or rubber tube into the evaporation pan underneath. Sometimes the tube becomes clogged, causing the condensate to accumulate in the bottom and leak out. The tube should be unclogged to restore normal drainage.
Sep 21, 2015 | Refrigerators
Maytag washing machine leaking
it could be coming from different sources. Most likely is the hose. You might need to replace hoses that bring water to the machine, but first check that they are not loose or have cracks that could cause these leaks to occur.
Jan 05, 2014 | Maytag Washing Machines
My Samsung WA5471ABW top- load washer is leaking from underneath. Is there Nything that I can do to self-repair?
You bet there is. But first let's double check some common causes of leaks that may not be located under the machine. Step one is to check the drain hose behind the machine. If a machine gets pushed back too far it can kink or bind that hose and that can cause water to leak from underneath. If that looks okay check that the end of that hose is not inserted into the drain more than about 4 - 5." If it is poked down into the standpipe more than that it can cause a syphoning situation that can also cause leaking underneath. While you are back there check the hoses that lead up to the machine. Make sure the connections are dry. I can't tell you how many under machine leaks i have fixed that originated right there. Just run a finger under each hose connection. If finger gets wet the connection may need tightened ever so slightly with pliers. If all those check out fine let me know. We'll go deeper.
Jan 13, 2013 | Samsung WA5471ABW 27" Top-Load Washer with...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking onto the floor from underneath the refrigerator.
There is a condensor tray located underneath. It catches water and then the water evporates. Sometimes the tube gets plugged and causes a mess. Check the tube and the condensation tray. You can access the tray by just taking off the grille under the door on the front of the refrigerator.
Nov 17, 2009 | Whirlpool EL7ATRRKS Refrigerator
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
The coils in the back of refrigerator are hot
The coils are supposed to be hot as they remove heat from the fridge which causes the fridge to get cold. The water under the fridge is from the defrost cycle that quickly melts frost in the freezer and sends it through a tube to a collection pan underneath. If there is water on the floor, the hose is misaligned or plugged up.
Jun 28, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Brown leakage
I've got a possibilty for you. moisture will build up in the cabinet of refrigs and then cause a little bit of rusty water that will leak out onto the floor. you could also have a plugged drain essentially causing the same thing to happen. look under you veggie bins for water build up. hope that helps. peyton
Jan 19, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
GE Profile PSS26NGS Side by Side Refrigerator Logo
91 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
