Question about Tomtom GO 910 GPS Receiver
Voice frequently not working. this problem intermittent. what do i need to do to ensure voice always works? Turning sound off and on again sometimes works. Turning on before using sometimes gets voice directios to start but voice missing after starting trip.
  • 466 Answers
Are you using a synth voice, or a sampled voice? If the latter, one of the voice files might be damaged, and in that case, as soon as the Tomtom accesses it, the whole voice function will shut down.
Try changing the voice and see what happens. The synth voice does not access any sample files and should always work (or never at all).
To restore the functionality, download again the voice files, or try restoring from the PC backup. At least, this worked for me when I had the same problem (but MY file was damaged at the end, so I was able to notice that the last thing the Tomtom said was always "In sevent*". The damaged file was, I suppose, the one with the word "seventy".
Posted on May 29, 2010
Wrench light comes on and car loses power. no codes being read
When you say loses power, if you mean it acts like it is turning off, you probably have a bad crankshaft or camshaft position sensor. When these fail they don't always throw a code. They do fail intermittently sometimes, then start working again.
Nov 13, 2015 | 2007 Lincoln LS
Panasonic Stereo Colour TV Model TX - 76PW10A Has frequent intermittent problem of no sound. Typically takes multiple tries to get sound working. Sometimes nothing comes on. Sometimes sound will...
i think there are no problem with your tv sum wire is missing it place
did u put headphone to TV sumtime if u plug a headphone in tv headphone jack again u short out your problem
Oct 19, 2008 | Panasonic Televison & Video
Radio and turn signals work intermittently on a 2005 wrangler
Im having the same issue and discovered if I jiggle the key in the ignition while turning the switch I got the blinkers and radio to operate. Shut it off and tried again, they work. but this has happened before and I think its more frequent. Im also thinking worn ignition switch. Hope it helps.
Apr 26, 2012 | Jeep Cars & Trucks
2002 Toyota Camry power door lock failure in higher temperature
look in the fuse box which is under the dash or in the engine compartment drivers side for the voltage relay fuse possibly square that powers the door motors and door locks . corrosion around relay or just bad relay replace and try power key lock release again and see if that works or first go into each door at a time and probe wire that leads to each door lock actuator motor and if you are getting proper current with helper pressing key to activate motor and proper current is displayed start replacing motors if intermittent wrong current or no current at each door checking with home meeter probing motor wire while helper is pressing key fob relay is bad and needs to be replaced. That is all i got good luck ps if all fails from that point replace key fob controler
Jun 13, 2017 | Cars & Trucks
My factory DVD player in our 2005 chevy tahoe LT is only working intermittently. The sound plays but the video screen does not always work. Turning it off and on repeatedly does not fix it. Waiting for...
I have fixed many of these with this problem.. I have found the wires from the unit to the screen that pass thru where it folds break. to fix it you have to remove and completely dis-assemble it, which is kind of a pain.... not guaranteed your problem, but the only problem I personally have had from that unit..
Jun 22, 2011 | 2005 Chevrolet Tahoe
Turning caller id off doesnt always work.I call my cell phone and it picks up the number. If this was a constant fault I could understand but its intermittent so without making any changes sometimes it...
If the number is programmed into your phone then it will always show the number. Delete all of your contacts and your caller ID will no longer work. I am assuming this is what you want.
Nov 08, 2009 | SJ Labs SJPhone (sjpwp) for PC
TV MODEL 32PF9631D 2 YEARS OLD INTERMITTENT FAULT BECOMING MORE FREQUENT - PICTURE DROPS OUT LEAVING BLANK BLACK SCREEN (ALL CHANNELS INCLUDING FOXTEL) BUT SOUND REMAINS. TURNING TV ON AND OFF WILL...
You have problem with the power inverter, in you tv it might be part of the power supply, in which case you will need just one board. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Televison & Video
Turn signals work intermittantly
multifunction switch? I think so.
Jan 29, 2009 | 1999 Ford Explorer
Machine will not turn on and voice quality on tapes is not good
The door cannot be adjusted, but the head alignment can be. If you open the cassette door, you should be able to remove the door cover. Then install your tape and put into play. You will need a small phillips screwdriver (like you would use on eyeglasses). If you look down towards the front of the cassette compartment, there is a small cutout, and below that the adjustment screw. Turn it very little at a time, first clockwise. If it gets worse go the other way. If it gets better, keep turning slowly until the sound is the best quality. As far as not turning on, check where the power pack plugs into the back of the machine. I have seen where either the pin in the receptacle is broken, or if you remove the bottom cover, the solder points are broken loose and need to be resoldered. (I was a tech for them for 20 years).
Oct 11, 2008 | Dictaphone 3750 Desktop Cassette...
Tomtom GO 910 GPS Receiver Logo
328 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
