Question about Home
When we switch on our shower we have lack of water pressure when the dials turned to hot. When it is turned to cold the pressure is good but as soon as we turn it to hot it reduces the pressure, what is the problem can you help
    Scholar:
  • 81 Answers
If your house was built before the "70's the most common reason is that the hot water trunk line to you shower has corroded shut to the point of reduced flow. It is not uncommon for this to happen on just one line. The controler its self could have an obstruction on the hot side. Replacing the internal part(s) should take care if this. Try to identify the brand of controler and research available part(s).
Posted on May 29, 2010
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
My American Standard R120 shower valve has excellent pressure on the cold side, no pressure on the hot side.
Could be a chunk of scale in the valve. Need to turn off water supply and take valve apart. If nothing is found, turn water supply on to give line a 'quick' flush and turn back off. If this does not help, you probably have an obstruction somewhere in the hot supply line and a plumber may be needed unless you are handy. Good luck.
Jan 01, 2014 | American Standard Home
Only cold water coming out of Redring digitemp shower
The temperature sensor in the unit is not functioning. It needs to be replaced!
Jan 14, 2013 | Home
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
Soon as i turn on the valve i get hot water .can't get just cold water. symmons temptrol
yes but you have to find the main lines going into your shower and switch them, just tell your guest a head of time or switch the hot cold lables
Jul 21, 2010 | Dmm Symmons Temptrol pressure balancing...
Lack of Hot water pressure
If its a tap refurde to, remove the head at the front of the tap and clean out the filter in front, if the houses warm water has low presure u must find ur presure redusing velve located on main cold feed to geyser and clean the cartrage out revit and ur presure must then be vine , let me know if that dosent help
May 28, 2010 | Danze & Single Handle Tub And Shower...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Triton Leona shower - when it is first turned on the water runs cold, as soon as the hot water begins to flow thru the shower trickles and then 1/2 wat thru the shower the cold water bursts into action and...
yes the hot side could be pluged with something . or cartridge has somthing in it. if the shower is new solder could have got into the valve. you need to make sure the water is turned off the the house and take it apart.
Jun 15, 2009 | Orange G1600 Series Emergency Showers
Home Logo
91 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
