Question about Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
How do I wire a Simer 2hp pump for 220v? - Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
  • 30 Answers
If it is capable of operating on 220, a diagram should be on the inside of the cover plate or the on the nameplate
Posted on Aug 26, 2010
Jandy Zodiac FloPro 2HP connecting Red Wire to which screw L1 or L2?
follow the owners manual.
if you are hooking this pump up as 220v, you will have two hot wires. one goes to L1 and the other to L2. it matters not which is where as they are both supplying power. be sure to connect the internal ground wire AS WELL as the bonding wire to the outside lug
Apr 28, 2014 | Zodiac Jandy 2Hp Flopro Pool Pump For...
Does the Red wire connect to the L1 or L2 Screw
when hooking up a pump on 220v, there are two hot wires. it doesnt matter which hot wire goes where. both L1 and L2 are power terminals
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
Shallow well and deep well packer installation will not stay primed
Do you have a check valve installed? If not, your water will be flowing back down the well and taking the prime with it.
Jun 21, 2011 | Simer ACE5C ACE5C Pump 1/2HP Deep Well...
Pump Housing is cracked. Can I replace the pump housing only?
To the best of my knowledge the housing is available seperatly but it is not cost effective in my estimation. I would try to use a epoxy type glue such as pro-poxy 20 or J.B weld and try to repair it. Hope this helps you and thanks.
Jan 02, 2011 | Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
Instruction Manuel or Schematic
Thank you for posting your question here on Fixya.com.
I am pretty sure the number you call the model or serial number is really the motor model number. If you go to http://www.simerpumps.com/ and select the owners manual tab near the top left corner of the page you will be able to enter the pump model number to get the manual you need.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 23, 2010 | Simer ACE5C ACE5C Pump 1/2HP Deep Well...
I need to wire a 2HP 110V ge motor to 220V
I think the only place you will get this info is from GE -- and good luck with that.
Apr 29, 2009 | Dryers
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Simer ACE5S  ACE5S Pump Well 1/2HP Ace 5S Logo
90 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Boyet Soriano
Boyet Soriano
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
