Question about Hotpoint VBXR1090D Top Load Washer
How to adjust the bowl for weight contol
The bowl on the washer bottoms out when water is added
  • 159 Answers
This is totally normal,some machines are suspended from the top by suspention rods x4,it is normal for the bowl to bottom out.unless the bowl is actually hitting the floor.
Posted on May 29, 2010
Honda GC160 pressure washer carburetor has a vinyl tube at the bottom, what is it for?
talk with a honda service shop
i suspect that it is a water drain tube to remove water from the bowl of the carby
Aug 20, 2016 | Honda Pressure Washer PSI 3000
Brigs n straton pressure washer won t stay running unless you put or keep starting fluid in in
Loosen the carb bowl nut until it begins leaking into the shallow clear glass bowl you placed beneath it. It may take a minute to have drained the water out of the bowl and another minute or so to get some more from the gas tank. With the glass bowl you will be able to see the water in the bottom and gas floating on top of it. When you see the gas on top then tighten the bowl nut and try to crank. (Choking helps draw out water still in carb) Return gas collected. to tank but do not let the water go back in.
Sep 12, 2013 | Psi Blue Max 2200 High Pressure Gas Power...
My fisher and paykel eco washer spins weirdly and makes lots of noises
Noisy
If the user is complaining about noise, it may be in a number of different areas. Is the noise during
spin? Is it a banging sound? This would typically be the drain hose, inlet hoses, mains lead or
harness. If it is an out of balance noise, check that the machine is level and stable. Check the
bias spring and balance rings. Remove the inner bowl and check that its weight is within
specification (Refer Section 1.12).
If it is a 'clunk' that occurs up to 3 times per cycle, this would be a bowl check and is completely
normal. It occurs when SmartDrive is draining and 3/4 empty. This is a 'feature' and a noise that
cannot be reduced.
Other things to check are:
• Is SmartDrive level and on all four feet equally.
• Check the mains lead, inlet hoses and drain hose outside the wrapper, behind SmartDrive.
• Check the harness and drain hose inside is not banging on the wrapper during spin.
• Check the bias spring is fitted correctly.
• Check the 2 balance rings in the inner bowl contain water. Check the bowl weight.
• Check for noisy suspension rods.
Apr 04, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
What would cause a Kenmore HE2 washer to turn off as the washer gets water/weight added to it.
check the wires under the tub. as the tub get weight in it it drops down a little bit it could be loosing or shorting one of the wires
Aug 28, 2012 | Kenmore HE2 Plus Front Load Washer
When I start my pressure washer on full choke it works fine when I place choke in wide open position gas runs out of the carburetor.what could be wrong.the engine issas by Briggs and Stratton.
You need to take the float bowl off the carb from the bottom . You haven't given a lot of information about who did what to the carburator but somebody must have screwed with the float pisition for this to be happening . The way all carburtors work is the same you have the float bowl and the floats and on top of the floats is a valve called the needle valve. Now the neddle valve is there to stop the flow of fuel into the float bowl when the engine is not in a high damand cycle for fuel like start up or ideal the choke shuts the air off and gives more fuel at start up .However when the engine is running and the float bowl is being filled by gravity feed from the gas tank the floats will move up do to the amount of fuel in the float bowl and should shut the fuel from the gas tank off to the float bowl until the engine can burn the fuel and drop the float level enough to make the neddle valve open again to supply more fuel for the engine to run correctly its a never ending cycle . You need to adjust the floats and likely clean the carburator don't mess with adjustments there mostly automatic when the engine is running
Sep 16, 2011 | Simpson WS4050V Water Shotgun 4000 Psi...
My eljer tank cracked and I need to install a new tank. How do I just install a new tank? The bowl is fine. Companies are trying to charge me about $300 to do this and I do not have the money. Please...
Let's assume you can buy the tank.
Installation of tank is simple.
If you can buy the eljer tank, you can buy whole new toilet with bowl and tank from home center.
We'll walk through instructions for both options.
1) How to replace tank on existing bowl.
-Tank is attached from underneath with two nuts.
-Turn off water, and hold flush valve down to drain tank
-Water connection is one nut. Follow supply line up to where it connects to tank. Loosen the nut that is around supply line just underneath tank. Pull nut downward and notice a black rubber washer that is probably stuck inside nut, or is stuck at bottom of tank. Make a note of where that nut is because it seals the water line to tank.
-You might also have a flex connector instead of supply tube. In that case, just unscrew flex connect from bottom of flush valve.
-Look beneath the tank and there are two nuts that hold tank to bowl.
-Take off these two nuts. A ratchet and socket is best tool, but you can use crescent wrench. -Notice these nuts are not exceptionally tight, but they are firm.
-Straddle the bowl and hold tank with two hands and lift up. Tank will come right up.
-Notice that on bottom of the tank: there are 2 bolts sticking out and there is a spongy rubber washer. This is the spud washer. Your new tank will have new washer. This washer seals tank to bowl so water doesn't leak when you flush.
-Notice round opening where flush water flows into bowl. Spud washer seals this hole. If you have experienced slow flushing, or if you have hard water, pour several cupfuls of CLR Calcium Lime Rust into the hole. CLR is sold at Home Depot by the gallon for $10.
-Open box to new tank. Find spud washer and fix it to bottom of new tank.
-Now a new tank is slippery, I want you to set boxes on floor nearby so if tank starts slipping, aim toward a box instead of hard tile floor.
-New tank comes with 2 new bolts, with nuts. Look at instruction sheet and see exactly how they want you to connect bolts to tank. Look carefully where they want you to put washers. These washer seal the tank when you tighten bolts.
-Now your spud washer is in place, the bolts are attached to tank and are sticking out of bottom of tank.
-Straddle bowl and lower new tank into place. Make sure spud washer lines up. Bolts line up. And flush valve lines up with supply tube. It's that easy.
-Tighten the nuts. Remember, not too tight. Toilet is not steel. And you can tighten more if there is seeping water.
-Now tank is in place. Raise nut and washer that are on supply tube and tighten nut onto bottom of flush valve. This nut is fairly tight. You might want to buy a new washer.
-If you have a flex line for the water supply, then just connect the flex line.
-Turn water ON a little bit at a time to avoid gusher if something is not correct.
-Use paper towels to check for dripping or seepage beneath tank. Tighten nuts appropriately to end seepage.
-Flush toilet and look for seepage around spud washer.
-You're done.
2) How to install new toilet.
-Remove old tank as shown above.
-Bowl is held to floor with two nuts.
-Ideal world those two nuts come right off and you lift bowl up off the floor.
-Real world, those nuts are rusted and you have to drill through side of the nut and bolt to break it off.
-Lift bowl up.
-Have cardboard ready next to toilet so you can set bowl on something. Or set it in bathtub.
-Bowl will be damp and wax ring is on bottom of bowl and will mess up the floor.
-Notice how the toilet bolts are set in the floor flange. Take photo if needed so you can put it back. It's real simple, but if you have never done this, a photo might help.
-Take putty knife and scrape wax ring off of floor flange. You want it smooth, but you don't clean it.
-New toilet comes with wax ring and bolts, but you might have to buy these at hardware store. Get wax right with gasket. The boxes are marked. Buy two of them.
-Set wax ring in center of floor flange. Gasket goes downward. Rounded side of wax ring goes up.
-Set new toilet bolts into floor flange. Keep bolts straight up using wax from the old wax ring, or from 2nd wax right you purchased.
-Keep bolts straight across from each other.
-Time to set the toilet.
-Stand in front of bowl and grab on either side at point where seat connects.
-Here's the fun part.
-Bowl has to go straight down onto wax ring so you have to be strong enough to hold tank level while aligning tank with bolts, without knocking the bolts down. Like a carnival game.
-Straddle walk toilet while holding it up high enough so it will not knock over the bolts.
-Lower bowl into place going straight down using bolts as guide. Lower a little bit and check one side for alignment and then check other side until bowl is going down and bolts fit through the holes.
-If bolt falls over or gets pushed away, straddle walk toilet back and set bolt straight up again.
-Once bowl is aligned, keep pushing straight down on bowl, and finally use your weight to push bowl to floor. Be careful to keep bowl perpendicular to wall so tank will sit straight.
-Attach bowl to floor with nuts and washers.
-Install tank as shown above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Jan 12, 2011 | Eljer 141-0220-00 Toilet Tank White
How do I balance the washer as well as the bowl inside . I have never been able to fully balance the washers base and I also am wondering if the bowl needs balancing and how to do both.
There are no balance adjustments, the drum is a floating design on springs and ,lower hydraulic arms. The drum is also weighted for passive counterbalance.
Nov 15, 2010 | Bosch Nexxt 300 Series WFMC2201UC
My kohler toilet is only about 1 year old. no problems with the flush but the bowl only fills up with about half the amount of the normal water. I looked inside an all seems to be connected. Thanks
You might follow this link to see if you can adjust the water level:
http://www.acmehowto.com/howto/homemaintenance/plumbing/toilet/filllevel.php
Hope that helps.
Aug 21, 2010 | Kohler Home
Super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Jun 16, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Washer Will Not Hold Water
What height is mentioned in your manual for your drain pipe (the outlet pipe for your machine) There should be a height (before u bend it downwards into the drain) or the water will just flow out........... And do not over-load your washer.
Apr 24, 2007 | Maytag PAV2300 Top Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
37 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
