LG37LB1DA. Turns on but no picture just static sound. Tried changing inputs but to no avail.
  • 19,396 Answers
Hi.
If the LED stays green and there is no back light (screen completely darl, then it is either power board or inverter. Testing is done reading volts at PSU connector and at inverter contacts.
If there is backlight but no raster or OSD (on screen menu), then the problem is the main controller board or the PSU.
If there is OSD but no picture, then problem is main controller board or LCD controller.
Testing is done activating the lines from PSU and reading volts on main board and inverter. Here a general description:How to test an LCD TV or monitor PSU.
Posted on May 29, 2010
  • Patrick McAlexander May 29, 2010
    Getting audio but no raster or osd. it is channel 3 on antenna input
  • Ginko
    Ginko May 29, 2010
    Hi.
    If you have no raster or OSD , then it is not the input. You get OSD even if an input is faulty, or if there is no antenna signal.
    If the TV has no backlight (completely dark), it is usually the inverter. PSU must be tested.
    If the TV has no raster but display has light, then it is usually the main controller board. PSU and iother boards must be tested.
    If the problem is only on antenna signal, and you get picture on DVD, then it is the built in tuner.
    Also test the TV after disconnecting power cord for ten minutes. Restart TV with only antenna connected.
    If you need to call a technician, ring LG at the number listed on the owners manual.
    Regards.
    Ginko.
Dp55360 no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 19, 2016 | Sanyo DP55360 55" 1080p 120Hz LCD TV...
Static jumping picture
sounds like bad connection or bad tuner in the tv - have you tried playing a DVD or VCR tape ( if available ) - more info would be needed to help you further -such as - are you on cable, cable box, satelite or antenna and do you hook up to your TV using the a/v or RF(cable) input.
Oct 18, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Sony KDS-50A2000 no audio
check you sound option in sound settings menu sound settings region ie i or b or auto mike shure u on i
Mar 28, 2009 | Sony KDS-50A2000 50" HDTV
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
Tv seems ok by static and now, no sound (or very faint)
The problem you're describing sounds like a tuner problem. BUT you say that you have the same problem with A-V input too. That's weird!!! Possibly the electronic TV-AV switching circuit is messed up and stuck in the TV (tuner) position. If this is the case you DO have a tuner problem and a switching problem too.
Jan 14, 2007 | Hitachi C29-F200 29" TV
FUZZY (SNOWY) PICTURE
When you say you have tried all the inputs you are not clear if you mean tuner, vcr, dvd, aux, etc. If you are talking about only the cable input it sounds like you have a bad tuner. To obtain picture in picture there are 2 tuners in your set. This would explain why the small picture is ok while the main picture is bad. You should be able to swap the signals (see your ops manual). Try this. If the snow moves the one tuner is bad. If you have put other signals in (besides cable)such as dvd then the problem is in the matrix circuitry where the two signals merge. Either problem should be easy for a good tech to solve and not cost a whole lot.
Jun 01, 2006 | Sony KP-53XBR200 53" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
