Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Disc not recognised by computer, orange light showing on front
Maybe a power problem? Disc starts up, but then a click and repeats.
  • 922 Answers
Orange light and clicking noise sounds like the hard drive has failed.
The enclosure should still be good so if you can open it and replace the hard driver you will be back in business.
Good luck.
Posted on May 29, 2010
Satellite L655 won't fire up, orange Indicator on front edge flashes
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 21, 2013 | Computers & Internet
The orange light on the start button comes on and nothing happens
prepare machine for use first.
half-fill water tank, switch on unit and insert yellow TDisk (service disc) barcode down. Close the locking unit securely loud click, press green light repeat these steps 3 times. After that you will have the stand by orange/amber. Remove the Service Disc and store in the recess behind the water tank, Insert a Coffee Disc, close the brewing unit with click and green light should be on. press and it should work.If not go to shop where pruchased. Warranty.
Dec 29, 2012 | Braun Tassimo Espresso Machine/Coffee...
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
My Samsung HX-MU010EA/G2 1TB portable hard drive is not working. It is not being recognised by my computer all of a sudden after about 6 weeks of use. The blue light flashes quickly but does not give...
Have a look in disk management if on win 7 or vista just type in "disk Management" in your search bar after clicking start button and see if it shows up there. If not try plugging into another computer and see what happens. If still no good you say only 6 weeks it should be guaranteed. If your data is important to you never trust just 1 source of backup maybe start copying to DVD's also. Good luck with it from Scott
May 17, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
Won't Start Up
try this link it might help you get start again. laptop Won Start Up Google Search
Oct 19, 2017 | Toshiba Tecra TE-2100 Notebook
My powerbrick lightis orange but my xbox360 wont turn on
If the light on the power brick stays orange after turning the console on it means the brick is not properly functioning. You can attempt to clean the power brick with a can of air. Also make sure it has ventilation and is not sitting on carpet. This can cause the power brick itself to overheat and cause issues with it and the console itself. Also make sure your 360 is not plugger into a surge suppressor as this can cause issue due to double protection.
If possible, test the power brick on a different console, and test the console on a different power brick. This will narrow down your problem area.
Dec 22, 2009 | Microsoft Xbox 360 Pro System Console
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
IOGEAR COMBO not recognised
Is your hard drive detected by the computer? Did you try changing the USB ports? You can check if the drive is detected by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your drive. If you dont then the drive is probably not detected. If you see, you can just re-format it from here and it will appear in your my computer.
Dec 21, 2007 | IOGear COMBO ION GHD135C160 160 GB Hard...
Click and light on front flashes!
This showing the tv have power. Maybe when you pushed the power button it clicks and shuts down then show the red light bliking showing one code. Some shurt on horizontal board or loose some voltage from power supply. This is not easy if you don't have experience with electronic. I'm sorry still tring
Sep 07, 2007 | Sony KV-35S66 35" TV
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
517 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
