Apple iPod touch Logo
Posted on May 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ipod touch is in a white screen and i cant get it back how it was what do i do?
Anonymous
Level 3:
President:
  • Master 2,185 Answers
  • Posted on May 29, 2010
Anonymous
Master
Level 3:
President:
Answers
2185
Questions
0
Helped
519900
Points
7044
Do a hard reset. Try to press and hold both the Sleep/Wake button and the Home button for like ten seconds or so just until the Apple logo appears.
Hope this helps.
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
My ipod nano screen has gone white and i cant see what i am doing on it. is there anything i can do to get it back? i found this problem after plugging it into my docking station.
if its no an ipod touch then hold the middle button and the menu button down at the same time for a while and see if it restarts
good luck....
Locked ipod
 Hi
if your ipod froze, just hold down the middle button for one second.. still holding it, press and hold the menubutton for 6 to 10 seconds. then the screen should turn black and after a few seconds a white apple should appear and the i-pod will restart and go back to normal.
please rate my suggestion...
White screen and power and home buttons wont work
oh yea man that happen to me u just by a new one
1helpful
2answers
Ipod touch 2 gb screen went white
that happens sometimes. whenever it happens, hold the power and home button until it turns off. then turn it back on
1helpful
2answers
My ipod touch has a white screen and it wont let me do anything
ok what u should try if it is still doing it is,
1) press the home button and hold it for 5-10 seconds.
2) if 1 doesnt work try restoring it on ur comp.
Ipod touch wont turn on
My 16gb touch just did the same thing, what i had to do was open up my ipod in itunes and restore it to its original settings. it will take some time to reset all your settings and resync all u'r music and applications but it worked for me. good luck!
1helpful
2answers
White screen on ipod touch
http://www.ziphone.org/
Use the Ziphone ipod touch and iphone jailbreak GUI to put the ipod in recovery mode. Then restore it using iTunes.
i had the same problem with 'band'
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
