Question about Whirlpool Duet GHW9150P Front Load Washer
F 02 flashing on washer
My washing machine is not working. It starts but then 5 mins into the wash cycle it stops and F 02 flashes. I'm not sure what that means.
  • Whirlpool Master
  • 8,220 Answers
Post your model number to this link for a tech sheet that will explain the
error codes or remove the panel and a tech sheet will be in their.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 29, 2010
    President:
  • 1,382 Answers
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Wash machine quits mid cycle
    Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
    Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    Washer starts wash cycle and runs for about 5 mins then stops and displays F 02 on the clock
    Hi
    Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
    • Check the drain hose and make sure it is not plugged or kinked.
    • Check the electrical connections at the pump and make sure the pump is running.
    • Check the drain pump filter for foreign objects.
    • If the above does not correct the problem, replace the pump.
    Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jun 21, 2010 | Whirlpool GHW9300 Duet Washer
    Haier washer/dryer combo not drying clothes
    Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
    Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
    He3t washing machine
    F02 is a drain problem. I took the back off the washer and cleaned out the drainage hose and I guess its a holding tank before it goes out. Both were very clogged with STUFF cleaned it all out now it works better than ever.
    Feb 03, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Kenmore Elite 42922 HE 3t
    sojds as if theresnot addeguate wate rsupply going to unit make sure
    both hot and cold water is supplied and working to the unit
    Apr 02, 2008 | Kenmore 46462 Front Load Washer
    LOC code flashing on washing machine
    Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
    Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    186 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
