Question about Hitachi 53UDX10B 53" Rear Projection Television
Letters on the screen are out of focus - Hitachi 53UDX10B 53" Rear Projection Television
  • 21 Answers
Could be adjust ment required on the focus block a part of the high voltage circuitry.. ususlly located..if you take of front grill, than remove a small panel..has 3-6 small knobs on it. Bottom three usuallt focus, one for each of the three lamps. or could be convergence misaligned..maybe time for a convergence repair. Two large black STK chips on main board.
Trace Electronics Repair, Barrie, ON
Posted on May 29, 2010
T.v. out of focus
On the back of this TV you will find two black potentiometers. The top potentiometer should be the focus. Remember, you want to correct the focus, so you will need to pay attention. The bottom potentiometer is the screen voltage. This one will darken or brighten the picture. Be careful not to turn that one. Find a channel with lettering on it to adjust the focus button [top]. Twist back and forth to receive the best location. You may even press the menu button and focus on them. Try that, give me a few hands and thanks for asking!
Sep 13, 2010 | GE 31GT660 TV
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
Diaplay Letters not cleard
Open your monitor's back cover and on the circuit laid underneath the CRT you will find a big black object. Check it, there will be two knobs having H- focus and V- focus, control them and your CRT will focus correctly. If still problem persists on the CRT there is a white box with three control knobs, adjust them.
Jul 24, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
I can turn my camera on then the screen picture is all blurry and it won't do anything if you press the button as if to take the picture. The one thing i have noticed different is the letters [CAF] in the...
When the camera is set to C-AF (Continuous Auto Focus) mode the focus is continually aligned according to movement of subject or the camera even when shutter button is not pressed. The Continuous Auto Focus (C-AF) is disabled while the camera is zooming in and out. Once the camera stops zooming the CAF is initiated and the cameras focus is adjusted.
This is actually used for video.
Jun 06, 2008 | Samsung Cameras
Samsung TXS 3082 HDTV focus problem
if there is no focus adjustment hole in the back of the unit it will have to be taken into a shop where a pro can adjust your vs and va voltages.
Mar 28, 2008 | Televison & Video
Reducing voltage for Sony KP-51HW40
G2 = screen...On the screen controls behind the front grill, behind the hardboard. 6 pots, 2 rows of 3 pots. 3 for focus and 3 for screens. 1 for each of the the red, green and blue guns/crts.
To adjust: Run set, change to black screen with tv/video button. Dial each screen clockwise untill you see a color. Then counterclockwise slowly untill that color goes black, then stop. Do this for all 3 screen controls.
If you need to adjust the focus then bring up lettering. I use the QVC channel for this. Focus is done by eye.
Mar 19, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA P46921. Just changed flyback.
First, this assumes nothing else is going on to cause it. Here's what I did. Go to the 'green grid' via the v76 menu and go through the alignment there. Notice that there are red letters, blue letters, and a green grid. While you are in this screen, adjust the red, green, and blue focus watching the individual color's item until they are in focus. If they won't focus here, they won't focus and you have something else wrong (what I do not know). Then, return to normal programming, then select menu on the remote, then screen, then adjust projection tv convergence both horizontal and vertical crosshare. That ought to get it.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
Screen Voltage
is the black box about 3inx3in insize and can you letters on it and may the words focus or screen if so thats it the pots are counter sunk and must be adjusted with an insulated screw driver ,if your not sure get a tech to do it for you.
Aug 26, 2007 | Samsung HCN4226W 42" Rear Projection...
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
