Question about Samsung SyncMaster 913N 19" LCD Monitor
LCD Screen Blank
CPU on but lcd power on off just blue light blinking...blinking. And also no light on the keyboard. Any idea what is wrong? Thanks.
  • 11,361 Answers
First, try this mnoitor with other PC, if it still does not work then you will have to open it up and inspect the insideand inspect the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 30, 2010
New to this site! Hope someone has an answer that can help... I have a LG 55 LCD flat screen model 55LD520-UA. Try to turn it on. Bottom light blinks red 3 times blinks blue once, then nothing.
Try to change the capacitors first. Normally lost of lcd tv have problems with the capacitors and which lead to powers problems. May you will not find visually that the capacitor is fault. So go for changing the capacitor also check the following video. Which will help you understand how to check the power supply broad. Also take care while working with the power board there is a risk or electric shock Also one of the capacitor in the power supply holds charge even when you have remove the power supply.
Testing LCD TV Power Supply BoardsSTEP BY STEP
www.electro-medical.blogspot.com
Oct 30, 2015 | LG Televison & Video
LCD screen blank
u need to tune it in to ur channel
Apr 24, 2014 | Baby Lock Sewing Machines
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
My dell moniter shows purple light at the power button instead of blue/orange.... and its not workin.. wat could be the problem
First of all you need to check you keyboard light it may be the issue with your CPU. So check you keyboard light and press Num lock key if it's getting on/off when you are pressing the key. If it's working or not. It must be blink when you press the num key. If it's constent or not getting on then check with you CPU first ....may be there is some issue with you CPU. Second you can remove the cable from CPU which is connecting to monitor to check ....when you remove it from cpu it will give you some message on the monitor screen that check you vga cable etc. If it give's such message then it will be for sure then you need to your CPU fixed up.
So please comment back with your troubleshooting details , hope it will help out you.
Thanks Sanjay Kumar
Apr 26, 2011 | Dell SE198WFP LCD Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
My Gateway monitor light blinks blue slowly but the screen is blank. I rebooted, and the computer came on, but the screen doesn't. We plugged in an old monitor, and it works. Does the slow-blinking blue...
More likely to be problem in the power supply.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 11, 2010 | Gateway FPD2275W LCD Monitor
My wife's mom bought us a desk top p.c with this samsung 906bw
Well, seems like the CPU is the source of the problems, not the LCD Monitor.
The simple way to check it is by remove the cable from CPU unit, see for any sign such us color pattern moving or any sign.
the other way is, try using other CPU or Laptop, then connect it to the LCD Monitor.If it works, then you need to repair your CPU.
Hope it's working
Feb 22, 2010 | Samsung 906BW LCD Monitor
Sceptre naga blue screen when tv on then turns blank, sound on
i have a secptre t v turns on for a sec and screen is blue then goes to blank screen can anyone help
Apr 18, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Samsung SyncMaster 913N 19" LCD Monitor Logo
160 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
