Question about Panasonic Viera TH-50PX80U Plasma TV
Panasonic plasma repair. TH-50PX80U something
Panasonic plasma television repair. TH-50PX80U something popped and smell like burning burning
moved into new apt. comcast cable installed and next day this happened. the power light of televison was flashing. I am broke and my wife left me 5 months ago. Hope someone can help a brother out
  • tmck59 May 29, 2010
    Panasonic viera plasma TV TH-50PX80U
    TV power light began blinking and then heard a pop sound and a burn smell.
    Preveious expert, check capacitors and if bulged/swollen and then replace them.
    The yellow tape like attachments (the capacitor?) I cannot find capacitor on site I was led to Parts.com Do you agree with diagnosis and where and how much for parts
    Thanks
    Terry
  • tmck59 Jun 06, 2010
    the capacitors are not damaged. The high voltage board was arcing. After looking over board and inside board, It seems a cat has pissed on the TV. The high voltage board is cleaned up. When turning on the TV it did not arc. The power light is blinking and not turning on. Now I guess it may be a transister on the power board. I don't have much money, which is why I am trying to repair myself.. My friend who is good with electrical things and needs a schematic of the board. If I were to buy a recycled board. What is the board callled. I tried parts.com and does not find a board searching power board. just things like printed board
  • Panasonic Master
  • 11,800 Answers
Most likely a capacitor failed (or more - usually they fail in bunches), easy to fix (just some soldering to do) and a cheap part (less than $2 a piece) - find them and replace them. If you're lucky this is the only thing that has failed, otherwise you will have to test (and replace if necessary) the transistors from the power source.
Posted on May 29, 2010
  • Azrael SRL May 29, 2010
    Unweld all of the capacitors that look damaged, note their capacity in uFarads and the nominal voltage then go to any hobby shop that sells electronic parts and buy them (if necessary go with the old ones and ask for identical replacements), then weld them back in. As i said capacitors are cheap - less than $2 for one. If you can't find a shop near you go to a site like
    http://www.talonix.com/shop/category.asp...
    If you're lucky that should be enough.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.The popping sound you hear is usually from a bad cap on any of the boards inside. However, to check what has gone bad you’ll have to open the back of the unit
you’ll need to check bulged/swollen capacitors on power supply board. As the unit won’t even stay on for a long time so it means that it is the power board which is causing this issue. These issues usually happens due to overheating in plasma TVs after sometime, as these sets are very hard working device and produces a lot of heat.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 3 more comments
    are the capacitors the three yelow tape like looking atttachments to board they are wrinkled ??
    one small yellow similar to the three
    if so , are the parts availiable
    Thanks
  • Rylee Smith
    Rylee Smith May 29, 2010
    Yes right, you can obtain the parts from this link. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Thanks for your help
    exactly which part # and description would I need. recycled ones usually good ?
  • Rylee Smith
    As I said earlier that you'll have to check the capacitors on the power supply board and replace them with a new one, also if you get a refurbished power supply board thats in good condition you can buy that to avoid any further issues.
  • Rylee Smith
    Rylee Smith Jun 06, 2010
    OK, you are right it is the PCB. Moreover, you can call them at 1-866-925-7278 before buying the board. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Panasonic TH50PE8U
Panasonic Product Support - TH-50PX80U
shop.panasonic.com > Get Support
PanasonicOwner's Manuals. Owner's Manuals and Documentation. Operating Instructions Manual- TH-50PX80. Warranty. Warranty information. Warranty - TV Plasma ...
Panasonic TH-50PE8U Flat Panel Television User Manual
tv.manualsonline.com > ... > Panasonic Flat Panel Television
... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
Oct 29, 2015 | Panasonic Televison & Video
Need code for 7 blonks on power button
www.ask.com/
www.wikipedia.org/
www.infolinks.com/
www.info.com/panasonic_viera/plasma/tv/th42pz80u/blinks/7_times/and/black/screen/mean/
most likely failure of module in the tv, most likely fuse, capacitor, something burn up, find the air vents smell the area your smelling something burn up smell, if you have every smell electronic stuff burning up you will understand what i mean you will never forget that smell.
Oct 06, 2015 | Panasonic Viera TH-42PZ80U Plasma TV
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
Reset child lock code on Panasonic TH-50PX80U tv without remote
You can't unlock the child lock without its remote cotnrol.
Jan 16, 2013 | Panasonic Viera TH-50PX80U Plasma TV
What is a pcb printed circuit board and where are they located on a th-50px80u plasma tv
A PCB Printed circuit board is every single board in your TV. That is what PCB stands for Printed Circuit Board.
Jul 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
CONNECTING THE SET TO MY SURROUND SOUND SYSTEM.
What surround sound system can I buy to go with my panasonic viera th-50px80u plasma tv. One where I can here sound from cable and bluray
Jul 03, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Panasonic Viera TH-50PX80U Plasma TV Logo
400 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
