Question about Kenmore 44042 Front Load Washer
I have a Kenmore washer, model # 44042. Occassionally, it does not spin, the door won't unlock, and it just humms. I've simply start the cycle over, an it's all good, until the next time. Will a heavy load cause this, or is there some other reason, and solution??
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
Most Kenmore front load washers will not spin if they do not drain properly. Here are some tips to help resolve a draining problem…..
Check the washer for excessive suds. The washer will normally not drain properly with excessive suds present. If you see suds, let the suds dissipate and then run a drain/spin cycle to finish the cycle. Use less detergent. Make sure that you are using HE (High Efficiency) detergent in the proper quantity. You may need to drastically cut back the amount of detergent that you are using. If you have a water softener, you may need only a tablespoon of detergent. If you have been using too much detergent, then you may have detergent dissolved in the fibers of the clothes. This would create the need to cut back even further on detergent for a while until the detergent is rinsed out of the clothes properly.
Check the washer drain to make sure that it is clear. Check the drain hose for kinks or clogs. Makes sure that the drain hose is not stuck way down the stand pipe behind the washer. Also, do not tape up the stand pipe opening around the drain hose so that it is air tight. These issues can cause siphoning of drain water back into the washer.
Some Kenmore front load washers have a drain pump clean-out filter that you can access by unplugging the washer and removing the bottom front service panel. One type of Kenmore front load washer is shown in the images below. If you have this type of washer, you can access and clean out the large item filter.
If there is still water inside the washer, it will pour out of this filter when you remove the cover. On this type of washer, you can manually unlock the door by reaching up through the bottom and pulling the manual release tab on the door lock assembly to unlock the door. Use a wet/dry shop vacuum or other means to evacuate as much of the water as possible from the washer tub. Arrange towels to catch residual water when you remove the large item filter from the pump. This may resolve your drain problem in the washer.
Once you resolve the drain issue in your washer, it may start spinning properly.
Let us know if you want to know something more else please accept the suggestion.
Thank you.
Posted on May 29, 2010
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 12, 2011 | Kenmore 24032\24036 Top Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Wont spin drum for wash cylce or rinse spin cycle
first off how old is this machine?
you could look to see if the door switch is being made up, most problems come from the switch not being made up, it tells the rest of the machine to perform the rest of the functions, try that and let me know.
Mar 03, 2011 | Kenmore 44042 Front Load Washer
Lost user manuel. The washing machine (44042
bad news,mostlikely it's the spider gear and that means new washer time.using to much soap does this.it eats at the rear bearing and actually breaks it off and that's the sound you're hearing the basket has no rear bearing to ride on any more.you can first check to see if the shocks are broken,but most of the time the shocks break because the rear bearing is gone but check that first,i've found some with just a broken shock from overloading the washer.good luck and sorry to give you the bad news,the spider gear costs around 450 to 500 hundred bucks
Jul 25, 2010 | Kenmore 44042 Front Load Washer
Kenmore washer humms and smells horrible....
You have a bad motor. ( very common) If you take your model number to a local used parts store you may be able to find a good used motor for cheap. If no luck finding a used one, Order it from sears. (the motor is deffinately your problem, I replace them all the time.)
Nov 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer 44052
Mine issue was a loose connection. I removed the back panel and pushed in all the wires. The washer started working again. If you take off the back panel and the belt is broken then that could be your problem. Unplug the washer first.
May 22, 2008 | Kenmore 44042 Front Load Washer
Kenmore 44042 - No spin cycle
The front load washers are supported by springs on the top and shocks on the bottom.  More than likely you broke a spring on the top or cracked one of the shock mounts which causes and unbalanced load all the time.  Will it go through a spin cycle with no clothes is it?
Oct 17, 2007 | Kenmore 44042 Front Load Washer
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Jun 17, 2007 | Kenmore 44042 Front Load Washer
Kenmore 44042 Front Load Washer Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
