Question about Sony Handycam CCD-TRV27E Camcorder
Cant get it to play or rewind but will fast forward
    Sergeant:
    Champion:
  • 338 Answers
Just needs head cleaner put through camera, available from most good camera shops.
Posted on May 29, 2010
Model mp820 mp3 player. how do I fast forward?
Cheapo MP3 play with rewind and fast forward - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1687936
Digital Spy Jul 5, 2012 - 13 posts - ‎2 authors
Cheapo MP3 play with rewind and fast forward Tablets and e-Readers. ... can anyone recommend a cheap MP3 player that will allow you to fast forward, ... the yepp yp55 t had a wonderful "scroll through" function that took ...
Oct 20, 2015 | Coby Audio Players & Recorders
How do i get a sony microcassette transcriber m-2000 to play/rewind/fast forward continuously?
Probably has a bad sensor belt (small belt attached to silver and black reflective wheel).
Aug 07, 2014 | Sony M-2000 MicroCassette Transcriber...
I have a Sherwood DS1150 tape Deck. Problem Cant open Cassette Door, tape is inside . Will not rewind or fast forward. Wont play. Any advise
Very likely the tape is wound around the capstan.
You may have to get at it by taking the unit's case off.
If I am right you might have to destroy the cassette unless you are very careful. Or, at least, have to cut the tape so as to unwind it from the capstan.
You could also try to open the door just enough to lift it up and off ... as if you were going to clean the tape heads.
Mar 12, 2012 | Audio Players & Recorders
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
Apr 22, 2010 | JVC HR-J461MS VHS VCR
Teac HDR2500T Fast Forward/Rewind problem: It
easy, download the software update from the teac website- had the same problem myself
Jan 10, 2010 | Televison & Video
Does not play. will rewind & fast forward
Its most likely the cam gear. Any sony dealer can replace the gear.
Jan 07, 2009 | Sony BM-87DST Desktop Cassette Transcriber...
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Video Cameras Logo
43 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
