Question about Scytek Electronics ASTRA200 Car Alarm 1 Relay 5button Remote
My ASTRA200 wont work at all
I bought this alarm system a while ago. it worked fine. the other day i unhooked my car battery to work on my car and when i plugged the battery back in the alarm didnt work anymore. i know i have all the wires in tact. nothing is cut, unplugged, no fuse is blown and my remote works fine and so does my car. i need help. im not getting any lights or nothing from the alarm system
2 Suggested Answers
SOURCE: bought this car, dont know how to use the remote start
To add a transmitter on an AstrostartTM Remote Car Starter, follow the
following steps:
• Open the hood
• Turn the key to the ON position
• Push and release the brake pedal
• Cycle the ignition OFF - ON – OFF – ON – OFF. Warning! At the end, the key
should end at OFF. If sequence is made successfully, the parking light will
blink 4 times.
• Push any button on the transmitter to enter in learning mode and the parking
lights will flash 1 time. Repeat the same sequence for any additional
transmitter that needs to be learned in the system.
• Push the brake pedal once
End of programming
Posted on May 19, 2010
Skytec Astra alarm system just quit working unexpectedly
STOP STOP STOP STOP STOP STOP OK OK OK OK OK OK OK OK OK OK OK OK
Oct 01, 2013 | Scytek Electronics ASTRA200 Car Alarm 1...
Skytec astra alarm system keeps losing power
The batteries take a lot of power to send and receive data so you should get around 3 to 4 weeks per battery. If this is what you get it is normal.
Car is "dead" but battery/alternator/starter are all in working order. Hornet is causing this.
Sounds more like a faulty battery terminal to me from your description ,try cleaning and make sure its tight then smear with petroleum grease.Clean terminal with a kettle of hot water first
Jul 26, 2013 | Cars & Trucks
Why doesnt truck show trouble code or engine light and not start aftr sitting all day?
I would have a load test done on the battery/s as you may have a failing cell. Remove battery terminals and clean both posts and terminals with sandpaper until you see shiny metal. The black coating is lead sulphate which has a high resistance to
current flow both into and out of the battery.
Apr 07, 2013 | 2001 Dodge Ram - 1500, Quad cab, short...
To whom it my consern my dodge neon sxt alarm is just going of for no reason and when i turn it on or it wont even turn on and it just goes of i tried the using the car hand alarm thing but it wont stop it...
check the battery in the fob it may be bad if the battery is try unhooking the cars battery for about one minute this should reset the system. if that dosent work then youll will have to chase down the open circuit thats causing the alarm to activate.
Sep 11, 2011 | 2003 Dodge Neon
1991 GMC sonoma ignition turns on but wont crank
check your battery first,  Then measure voltage to the starter solenoid.  No voltage at solenoid the problem is at the key switch.
Mar 08, 2009 | 1991 GMC Sonoma
Car alarm wont let me start the car it wont stop going off
try unhooking the battery while the battery is disconnected turn the ignition on leave the ignition on while you reconnect the battery this should override the alarm
Jan 31, 2009 | 1994 Volkswagen Golf
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
Scytek Electronics ASTRA200 Car Alarm 1 Relay 5button Remote Logo
57 people viewed this question
Top Astra Vehicle Parts & Accessories Experts
xxxxxx xxx
Alan Springett
Are you an Astra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
