Question about Samsung YP-U3 MP3 Player
Not detected by computer - Samsung YP-U3 MP3 Player
    President:
  • 2,185 Answers
Try to plug it to other usb ports on your computer. If it still not being detected, try to restart the computer then plug it back.
If it still does not work, plug the mp3 player to other computer just to test if this is a usb port problem.
Posted on May 29, 2010
Hard drive cannot detect
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 03, 2013 | Computers & Internet
Detect
May 01, 2013 | Transcend USA 120GB Storejet 2.5" SATA -...
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
NR serise wont detect hdd in bios
Nov 04, 2012 | Sony VAIO NR Notebook VGNNR460ES
Toshiba l450 h.d.d unable to detect from bios
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 23, 2012 | Toshiba Computers & Internet
Plugging in usb lead to computer.. XP computer doesnt see camera??
Some cameras need a driver to be detected, but some need the installation CD to detect the camera. You can use a card reader to have the computer detect the pictures, and drag and drop them from the card to the computer. The card reader will be detected in My Computer as another drive, i.e. f:, g:, etc.
Good luck and hope this helps.
May 27, 2011 | Cameras
Have seagate free agent go window 7 not reconizing the unit. please help.
You can try to use a different usb port of your computer check if it will be detected or try to plugged a different usb device see if it will be detected by the computer.If you have a different computer try to check if it will be detected. If the computer detects a different device it only means that the hard drive that you are connecting to the computer is faulty.
Thanks for using Fixya.
Jan 27, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
Why doesn't my computer detect my sansa m240 it worked before i tried other usb ports that didn't work i tried going to my computer it didn't detect it again please help
Apr 20, 2009 | SanDisk Sansa m240 MP3 Player
Samsung YP-U3 MP3 Player Logo
461 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
