Question about Toshiba 57H83 57" Rear Projection HDTV
No picture toshiba 57h83
Popped then picture went out but still get sound
  • 899 Answers
SOURCE: toshiba 57h83 wont do nothing
that relay is supposed to engage power to the tv boards that control the screen.
you will have to take it to a oualified service center , because they have access to parts that are needed for repair
Posted on Oct 17, 2008
Mastersage
  • 164 Answers
SOURCE: toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Mastersage
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-43H70-User's-Guide-TVRNME9EUT.html
Posted on Feb 18, 2009
  • 23 Answers
SOURCE: Toshiba 57" HDTV no red in picture
I had the 65" version of that TV. Loved it, unfortunately it went bad as well. It sounds like the red tube went bad. The tube itself might sell for $400 plus. The installation will take several hours with the alignments which will need to be done. Then after all that you will start to have to worry about the other tubes starting to deteriorate. If there is any red in the picture then the tube is most likely the problem. At tat point I would say buy a new TV. The best bang for the buck if you want size and have the space for it would be the new Samsung or Mitsubishi DLP's. I just installed one at customers house. The 60" Mitsubishi is 1400 at Best Buy Good Luck Rob
Posted on Feb 27, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: my toshiba 57h83 has a
Check your closed-caption settings and make sure they are turned off (or set to "caption 1" or "CC1" if you really want them). You will find the captions set for "text" now and that's why you see that black box sometimes. The set is blanking out a part of the screen for the text that never shows up. Most TVs have a single button to set captioning, so it's easy to press it and change modes without knowing it.
Please take a moment to rate this solution if it's cleared up your screen, and thanks for asking here!
Posted on Mar 20, 2009
easyab
  • 132 Answers
SOURCE: toshiba 57H83 and no longer get any sound. Any
Most often No Sound with Toshiba 57H83 is:
1. TV has a Sound on-off switch on the input panel at the rear of the TV. Very hard to see, black on black. Used to turn off speakers if you use a separate or external sound system for speakers. Usually gets moved while connecting hd cables or dusting and vacuuming in cramped space at the rear of the TV.
2. Someone accidentally changed Sound settings with remote to CC (closed caption) or SAP. Turn off in sound menu and save preference.
3. Sound input plugs from external cable or sat box unhooked or wrong input.
Toshiba 57H83 no sound fault is not common. If you still have no sound, get local service.
Or troubleshoot yourself to determine if Tuner, IF, processing, sound demod, switching or sound output circuit is smoked. Then make an installation plan.
easyab
ConvergenceRepair.com
Posted on Feb 28, 2010
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba 57H83 and no longer get any sound. Any
easyab
Feb 28, 2010 | Toshiba 57H83 57" Rear Projection HDTV
My tv made a pop sound and went black. i can still hear sound and change channels but just no pic. it will also turn itself off after about a minute, then turn back on and so forth. got any suggestions?
Sorry to tell you that one of your tubes went. There is a projector bulb and that is probably what went. Is is still under warranty? Check out this link below for a PDF detailed manual for your item Check out pages 59 and 60 for warranty information. The second link is for Toshiba support page. Just copy and paste link into your browser.
http://www.tacp.toshiba.com/tacpassets-images/models/57h83/docs/57h83_om_e.pdf
http://www.tacp.toshiba.com/customersupport/
Hope this helps. Let me know if I can help you out with anything else.
JimmyC
Oct 03, 2009 | Toshiba 57H83 57" Rear Projection HDTV
I need a speaker grill sreen for my toshiba 57h83 where can i purchase one?
They are available on the Internet---the part number for the speaker grill for a 57h83 Toshiba is :23527269 if you Google this number on the internet you will find a number of places that sell it; it has a suggested list price of about 152 dollars--if this was helpful please indicate by giving me a vote here.
Aug 12, 2009 | Toshiba 57H83 TV
I've got a toshiba 57H83 rear projection tv. Last night it crackle and went out. The power in the front was flashing. So I unplugged it and plugged it back in and it sounded like an electrical short. Could...
I have had a shorted picture tube do that on a Toshiba before. It could also be a Flyback transformer arcing.
You should call a good TV Tech for an estimate.
Aug 05, 2009 | Televison & Video
Feb 27, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba 57h83 wont do nothing
Oct 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Loss of picture and sound
Is the front panel power led flashing by chance?
Jan 09, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba 43 inch projection set
Possible bad solder connections in convergence circuit or vertical deflection circuit. This happens in alot of equipment. After warm up, expansion of joint pulls connections loose. Recommend not running like this, could cause component failure.
Dec 22, 2006 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba 57H83 57" Rear Projection HDTV Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
