Question about Gateway GM5442 Refurbished Intel Desktop Computer - Intel Core 2 Duo E4400 2.0GHz , 2GB D...
Gateway gm5442 takes a very long time to boot, but it finally does, after about 20 to 30 minutes. Have tried different processor,power supply, memory, and video card
  • Gateway Master
  • 4,924 Answers
There ar enothing wrong whith all of these...the memory it affects it the most ..I means tha Ram memory ...also it would not hurt to reinstall the operation system from scratch ..if it does the same than the motherboard has issues and probably it is gone ..if you changed the rest there is nothing else that can be ..
there can be a issue with the hard disk ..so when you boot it goes in a chack disk loop ..and that takes about half an hour to do ..and if it does it every time you open it ..than you should get the hdd..and format it head to bottom ..or replace it ...But first try to format it in another pc ..to make it quick ..than reinstall the operation system and it will work ..or ..just get another one ..at least for the operation system to be installed on ..and keep this one to store..iin..
Please do not forget to rate me ..
Posted on May 29, 2010
Testimonial: "am leaning towards a new board"
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Won't boot
3 BEEPS --RAM HAS IT HAD A POWER FAILURE AND DO YOU HAVE A SURGE PROTECTOR IS THE LIGHT STILL ON TO SAY SURGE PROTECTED
I have a gateway model # gm5088. I power on the computer and work fine, but the blue light doesnt work and the pc doesn't want to boot. What seems to be the problem?
sorry i could not understand u said it work fine but the pc doesnt want to boot. if its only the light issue then the connection of that light to the motherboard must be lossed or the bulb must have been fused
and if ur pc not booting then it ur power supply on *********** board problem
good day
May 29, 2010 | Gateway GM5088 PC Desktop
Gateway gm5442 very slow to boot, 20 to 30 minutes.
You said you tried different CPU, but it was the same motherboard, right? Maybe the motherboard speed (data bus, etc.) is just slow. Otherwise, there's not much left to try if the hard drive works OK in another computer and you've tried upgrading the memory, CPU, and power supply.
May 29, 2010 | Gateway GM5442 Refurbished Intel Desktop...
No beep codes,only flashing cursor on display. Removed ram, got beep code. Tried different processor and memory, still same, no beep, no display, no boot. Cannot access bios settings. Sounds like dead...
Sounds like a bad motherboard. To be sure, I'd remove or unplug all devices (hard drive, CD-ROM, etc) and verify. Sometimes, those devices can prevent a bootup. If you've removed all those and same thing, bad board.
May 27, 2010 | Gateway GM5442 Refurbished Intel Desktop...
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Turned off PC one night working fine. Next time try to use, PC wont boot. No video display, no bios, no posts, nothing. Gateway Desktop GT 5464 w/ integrated video, Intel E2140 Processor, Intel 945GC Mobo....
Have you tried booting it from yor CD drive with bootable software?
Any led flashing anywhere in the computer?
If not, we are talking about energy problem. Try fitting the energy cord firmly, try connecting the battery charger in a different power outlet.
Aug 26, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
I have a gateway GM5442 computer. Lately it has been giving me a warning that the power supply cord or something has been diconnected and I don,t even know what it looks like.
Usually you get messages like this when there have been temporary power outges and your computer gets shut off abruptly.
I wouldn't worry too much unless the computer acts weird when you start it up.
Apr 04, 2009 | Gateway GM5442 PC Desktop
Gateway gt5228- progressively worsening boot problem
I went back last night and tried the holding power button in with no plug in and it did not work. I even tried the trick of freezing the computer. It would not perform the same way more than twice. Once I got beeps and start up but no video. Another time it started up and gave me video. Ran great when it did decide to start (twice in 4 hours). I got the customers data off, took about 30 minutes. However on trying to restart it through windows it would not do it. I am giving it the diagnosis of failing motherboard as the symptoms are random and with varying problems each boot. No rhyme or reason to when it would start. I could leave it sit for an hour or I could keep trying to turn it off and then on again. I have eliminated the power supply as I installed another (larger) PSU in and it worked the first time, but with limited success after that. I eliminated the memory as I removed it and it made no difference, the PC didn't even tell me (through beeps) that it had no memory. I eliminated the processor as it does not behave like an overheating or bad processor as when it did start it ran flawlessly. I eliminated the BIOS as I cleared the CMOS through jumpers and BIOS did not indicate problems- like I said when it booted it ran great - as if there were no problems. I elimnated the hard drive as I was able to get the data off no prob. So this all points in the direction of motherboard. I think we are both in the same boat.
Nov 29, 2008 | Gateway GT5228 PC Desktop
Gateway GM5442 Refurbished Intel Desktop Computer - Intel Core 2 Duo E4400 2.0GHz , 2GB D... Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
