Question about LG WM-0532HW Front Load Washer
The pump runs during the wash cycle, but no water comes out of the sprayer near the door of the machine.
    Scholar:
  • 142 Answers
Most likely there is a bit of lint clogging up either the intake ports or the outlet. If you can get in there you can clean it, maybe with a stiff wire, and avoid service charges from a shop. Good luck.
Posted on May 29, 2010
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Water leaking from the front door during the cydle
check near top of drum where water enters machine that spout also needs to be kept clean. another possible problem could be the seal on door or drum could be loose or ripped check them both.
Jan 08, 2014 | Candy Washing Machines
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
if the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
May 23, 2011 | AEG Washing Machines
The soap does not seem to dissolve to clean the dishes and I do not seem to hear the water spraying during wash cycle
your rotator sprayers may be blocked or pump is broken,
remove rotator sprayers by gripping the stem and pulling or twisting out, check manual.
check that the holes are clear.
then try starting your machine with the sprayers out and see if you can hear the water.
if you dont hear anything the pump might be broken,
fistly check that the filter in bottom of machine is clear.
Jan 24, 2011 | Frigidaire Dishwashers
Dishwasher fills but no pressure during wash, middle and upper sprayer are not moving. I cleaned trap and lines in tub - no improvement. Is pump bad, how to test? Is this worth fixing?
What I would Do :
1st I would start your dishwasher and let it fill with water and when it stoped filling, I would open the door to see how much water it filled in the tub. ((( if you don't have enough water you will not get the correct pressure )))
If We have enough water we then close the dishwasher door and resume.
you have 2 motors in the bottom of your dishwasher, The drain pump motor and the Wash motor. They should be differen sounds.
We want to know if your wash motor is coming on.
If your wash motor is coming on then I will listen to see if I here water coming out of the spray arm. (( somtimes you can here the swish of the water hiting the door ))
If you do not here the water then I would open the door and position all spray arms the same way and close the door for a min and reopen to see if i have any movment.
If you do not have any movement and did here the motor run then your impellor might be broken or cloged or bound. you will only really find out by taking it apart. you could buy the hole pump & motor Kit. but you can save money by finding out what is the cause.
You can see a breakdown of a similar model here
I was unable to get your model to come up and you should check the machine model number so you have it to get the correct parts. Look at the pump & motor section and you will see how this pump is broken down.
If you don't think your getting the proper water amount, just open the dishwasher door and pour 5 or 6 glasses in and close the door for the wash cycle and listen for a differance.
Jan 08, 2010 | Whirlpool 24 in. GU1200XT Built-in...
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Machine runs through cycle but does not wash dishes
It sound like a pump issue. The pump is attached to the motor and forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck
Aug 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Washing Machines Logo
83 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
