Question about Kenmore PRO 24 in BuiltIn Dishwasher with Ultra Wash HE Filtration 13173
Clogged inlet valve/Kenmore Dishwasher model 15838
We have a Kenmore Ultra Wash dishwasher model no. 665.15838790 which seems to have an inlet valve that is clogged with mineral deposits. How do I get to this valve so that I can clean the screen? Thanks for the help!
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
  • 677 Answers
SOURCE: Maytag dishwasher filter keeps clogging
There is a product made to filter the water going into your dishwasher only to soften the water and remove the calcium before it enters your dishwasher. your dishes will be spotless and it will not get clogged again. you can get it at www.dishwasherfilter.com. it goes right under the sink and is very affordable. you will love this product and it will solve your problems.
Posted on May 07, 2009
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
  • 6 Answers
SOURCE: Dishwasher (Kenmore 665 Ultra Wash) won't drain. Suggestions?
I just fix mine today, august 21st. If you hear the pump running, which mine was, then there is a blockage more than likely. Mine was blocked on the inside of the drain hose inlet of the disposal. Pull off the hose and feel inside of the inlet. scrap it out and it should work fine.
Jeff
jeffscottmendoza@yahoo.com
Posted on Aug 21, 2009
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
Kenmore ultra wash dishwasher
Bad triac on control board. Replace control board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 23, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore dishwasher filling with water when not in use
The water inlet valve is defective.Turn off the power and close the valve to the water supply line Remove the kick panel on the front of the dishwasher remove the supply line, the clamp to the supply hose, the electrical connectors, ans the screws holding the valve. Reverse process to reinstall. Turn water on and check for leaks Turn on power and you are good to go
My dishwasher is not filling with water like it should for each wash cycle. Water flow from the faucet is good. What do I need to do to fix the problem?
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation (only if getting no water) may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity and also see if it is sticking. Here is a video checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Sep 17, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
No water
Two things to check. First see if anything is holding up the float inside the tub. Located on the bottom right if I remember correctly. I had a fork fall off the rack and do the exact same thing by getting lodged under the float. Second, if there was work done on the plumbing, some debrs may have gotten into the line and clogged things at the inlet valve. You may have water flowing through the inlet line, but maybe clogged at the valve. Need to take that off and check. While you are down there run the dishwasher through a cycle and test voltage at that valve. Also could be the valve or the control board.
Jul 14, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
Kenmore ultra wash dishwasher 15835 it runs fine, but when is sets after its finished it get water in it and you have to press cancel to drain it again. Any idea?
Water inlet valve needs replacing. (about $50 for the part)
The valve is leaking and allowing water to enter the dishwasher even when it's off. You can turn off the supply line shut off between uses until you get the part.
Jun 14, 2010 | Kenmore Dishwashers
Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore PRO 24 in BuiltIn Dishwasher with Ultra Wash HE Filtration  13173 Logo
425 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
