Question about Electrolux EW1000i Front Load Washer
E56 on electrolux EWF14108W - Electrolux EW1000i Front Load Washer
  • 27 Answers
E56 is a motor or motor control circuit board fault
Posted on Jun 25, 2010
Frigidaire dryer. What do the error codes e56 and e9e mean?
sounds like you need to consider a new dryer .
May 19, 2015 | Dryers
What does error code E56 what does error code E56 mean
Unfortunately, and error code of E56 indicates a high motor current. There are a couple of issues that could cause this problem and if you're comfortable working on it yourself, I can try to direct you to self-help website that will explain how to diagnose the issue. Be advised it will require some machine disassembly to test whether it's actually a motor problem or if there is an issue with the tub assembly being difficult to turn.
Mar 06, 2015 | Frigidaire Washing Machines
What does e56 error code mean
Good afternoon friend, thank you for allowing me to assist you!
Typically on a Frigidaire washer an "E56" error code stands for a high motor current. Which means you could be seeing an issue with your motor or speed control board. If you are getting that error code you could be seeing a miscommunication within the appliance, I would suggest a reset to your washer would clear any false error codes. You can reset the appliance by unplugging the power cord or flipping the household circuit breaker for ten minutes. I hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
E56
Hi Susan, this is JK. I understand that you are receiving an error E56 on your washer. This error E56 is indicating a high motor current, the motor has overheated. The washer motor will stop when it is overheated, allow the motor to cool down and attempt to wash again. If the problem persists, you would need to contact a service provider to test the motor, motor pulley, tub pulley and the bearings. Hope this helps!
Mar 24, 2014 | Frigidaire Affinity ATF8000FE
Washer would not drain or spin (frigidaire aft6000sf1) error code E56
Hello - Typically, error code E56 commonly refers to a motor issue. It indicates that either the motor has overheated and/or will not drain/spin. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately 30 minutes for the washer to cool down and turn the unit back on. If error code persists, I personally suggest contacting a professional to accurately diagnose the issue at hand.
Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
Affinity front loading washer error e56, what does this mean?
1) Read the owner manual and proceed section troubleshooting,this mean the motor, probably is defective and need replace.
2) Try to run the software diagnostic.and make the test 9 for solution or diagnostic.
3) or call some tech from company or another you know it
God bless you
Sep 26, 2012 | Frigidaire Washing Machines
Electrolux EWF14108W WONT START SOMTIMES AND TURNS OF HALFWAY THROU THE CYCLE
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Jul 07, 2011 | Electrolux Washing Machines
I HAVE A KONICA 7145 COPIER WITH AN E56-1 ERROR
Main control board unit has been modified to prevent abnormal code.
[How to identify the style]
Current and new styles can be distinguished by the part number printed
on the main control board unit.
(Current) 40LA-9025 => (New) 40LA-9026
Serial Number Cut-in: 40LE02201
TRY
to reseat all the board connections first..
hope that help
Nov 11, 2008 | Office Equipment & Supplies
90379 Sakar Camera
In this case wat u can do is remove the memory card and the battery from the camera and then give it a try because E56 means there is a problem with the memory card
Oct 21, 2007 | Sakar 90379 Digital Camera
Electrolux EW1000i Front Load Washer Logo
197 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
