Question about GE Advantium 120 Convection/Microwave Oven
My Advatium oven died, no power. Checked circuit breaker, that's ok. Not sure how to determine if this is a fuse problem. Model # SCA2001BSS 03
  • GE Master
  • 9,047 Answers
Assuming the power outlet is okay, I would suspect the 20A fuse, the oven cavity T.C.O. or the magnetron's T.C.O.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It also contains the installation instructions,
Accessing some components (especially the oven cavity T.C.O.) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 30, 2010
  • Marisol Davila
    Marisol Davila Oct 18, 2013
    What is the wire harness connection on the top are burnt. What does that mean?
H7871SOGB/03 combi. Why isn't it working?
The fact the breaker in the fusebox tripped indicates a fault in the appliance that is probably safety related. If it was the mcb (micro circuit breaker) it indicates a sudden overload. If it was the rcd (residual current device) it indicates there might have been a live circuit shorted to earth.
The fault is likely to be internal and it is potentially dangerous for unqualified people to fiddle about inside microwave ovens. Many brands are cheap throw-away items these days because a visit to the repair shop tends to cost more than a replacement.
The Neff brand is a premium brand and although repair costs are expensive it is likely to be (marginally) cheaper than a replacement.
Sep 04, 2015 | Neff Microwave Ovens
Microwave oven no power
The main fuse is probably blown.
When replacing, try to determine the cause.
if it has a bad door switch, then the monitor/short switch also must be replaced. On an inverter, replace the power relay as well.
If the fuse holder is not holding the fuse securely, then it will heat and blow.
A failing component in the high voltage circuit can also cause the problem.
Apr 04, 2014 | Whirlpool GH7208XR Convection / Microwave...
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
Does the rf375pxdw whirlpool range have a fuse or reset button? burners and oven does not work. there is power from the 220 plug into the range and the clock operates but not the 220. I checked circuit...
No reset buttons or fuses. Find the circuit breakers for the unit, it should be a double breaker with at least 40 Amp rating. Push it to the off position HARD (make sure not to pull the breaker out of the panel doing that). Turn it back on. Check voltage in the range power outlet. It should measure 220-250 Volts between the right and left connectors, and 110-125 Volts between the center and each side connectors. If not - problem is in the wiring or breaker. If you get those voltages and the range is still not working - problem is in the range itself. Check for shorted and loose wires.
Dec 18, 2009 | Microwave Ovens
We have had a lot of problems with the Advantium overheating and blowing the thermal protection fuse or switch located on the left side of the microwave. It was replaced twice under warranty, and a...
Thats a defective product, and it should have just been replaced with a new one under warranty. Any device that is blowing out a recomended fuse rating frequently is defective. The product itself is overloading the fuse, and making it blowout. Do not under any circumstance replace it with a higher fuse rating. This will make the product a fire hazard. The technician should have looked into the problem which is not the fuse.
Nov 25, 2009 | GE Advantium SCA2001BSS Microwave Oven
GE Microwave JVM1870SK03-NO POWER TO UNIT, PANEL DISPLAYS ARE ALL BLACK, CIRCUIT BREAKER NOT TRIPPED. The oven was actually working, then suddenly in the middle of warming the food, it did quit -...
change the units internal ceramic fuse and try this,may just be a fuse or if new one blows then could be h.v. diode.capacitor,thermal fuse,magnetron tube
Nov 09, 2009 | GE JVM1190 Microwave Oven
No power,does not turn on, checked breaker and reset plug
check the interior ceramic fuse they are available at hardware stores, if new fuse blows,suspect h.v. diode,capacitor,or the magnetron tube
Oct 28, 2009 | GE Advantium SCA2001BSS Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
583 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
