Question about HP Photosmart C5180 All-In-One InkJet Printer
Tells me it needs paper
It has paper
  • HP Master
  • 4,924 Answers
Insert more..and make a reset first cause the sensor do not detect it ..so it is either too little paper inside..or it has an error and needs to be reset..
Posted on May 29, 2010
I have a brother MFC260 and the machine says that there is no paper when the paper tray is full and inserted correctly. I found a white plastic part that was somehow attached to the inside of the printer...
There should be a slot on the paper tray in the right hand side, the part gets fitted into the slot and pushes on a pressure sensor to tell how much paper is left. Alternatively you could find the pressure sensor and Gerry rig the device so it always shows that you have paper left, and the printer will not tell you how much paper you have left, but it will tell you when it is out.
This problem should also be covered under the manufacturers warranty.
Mar 23, 2011 | Brother MFC-260C All-In-One InkJet Printer
I am having trouble trying to print card stock paper
110lbs?
that may be too heavy, try a few first then check if the printer will initiate printing.
Jun 26, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Paper starts then stops before printing results
most likely wrong paper or a bad optical sensor. There are actually 2 or 3 different versions of the mac 1200 all of which might need different paper. if you tell me the serial umber of your unit and the part number for the paper you are using I can tell you what is the correct paper.
If you have further questions you can contact me at wats@mesasales.com or through our website www.overstockme.com
May 27, 2010 | Ge Medical Systems Ge Healthcare Mac 1200...
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
How to feed paper in
Hi !
I shall provide you with the online manual.
http://www.sharpusa.com/files/fax_man_uxp100.pdf
In this page no 12 and 13 tells us how to feed the imaging film in.
Page 14 and 15 tells us how to feed the printing paper in.
pages 33 34 and 35 discusses how to feed the papers which needs to faxed .
Hope it helps !!!
Good luck !
Jun 30, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
My hp printer is telling me that i need to add
Not sure what printer you have but most consumer models don't actually detect paper in the tray. These machines will give an out of paper error if the paper is not picked up from the tray.
If the machine sounds like it is trying to pick up the paper but giving the error check and clean the pick up roller and look for something blocking the paper path.
hope this helps
Mar 15, 2009 | HP Office Equipment & Supplies
Keeps telling me to put paper in tray-tray is full
It sounds like it has lost how to detect the paper tray, this could be possibly the paper tray itself or the configuration on the machine its self, look on the tray and see if it has a paper configuration slide or a magnet on the side or front that is missing, or you will need to go into the menu configuration and choose the paper tray.
Good Luk
Jan 29, 2009 | Sharp AL-1655CS Copier
PANASONIC KX-FM386CX DRIVER NEEDED
Kindly help me to down load install this machine
P K Kutty
May 01, 2008 | Office Equipment & Supplies
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
HP Photosmart C5180 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
