Question about Dell E151FP 15" Flat Panel LCD Monitor
Computer monitor display blank, LED flashes green
I have a Dell flat panel display E151FPb. The green LED light next to the power button is constantly blinking, but the display is blank. What might the problem be? Everything is plugged in properly, the display was working a few hours earlier. I went in to use the computer and the green light next to the power button is flashing and the screen was blank.
  • megangatlin Jun 01, 2010
    Yes, I was able to solve the problem. It was the monitor. Thanks
  • Dell Master
  • 4,737 Answers
There are numbers of causes for the monitor black out. The most likely case with yours is with the over heating problem. What i mean is not the monitor, but the cpu components like processor, ram, hardisk, or whatever it may be. So you need to check them once again. As the first step, please disassemble and clean all the parts inside. If you have coolant paste, apply little paste on the heatsink. Blow away all the dusts, and again after you've finished cleaning, assemble the machine, reconnect everything and reboot the system. Sometimes the display refresh rate can cause the problem, but i don't think, that's related to your problem. If there's no internal defect, we can troubleshoot and fix it somehow. There are number of measures. If the above given tricks can't fix it, let's try another. Do let me know. Good luck.
Posted on May 29, 2010
  • 3 more comments
  • megangatlin May 30, 2010
    Unfortunately, that did not work. I cannot tell if the monitor is off or on. If it is plugged in the power light constantly flashes green, regardless of whether the computer is on or not. I cannot make the light stop flashing unless I unplug the monitor.
  • Lebanon Raingam
    Lebanon Raingam May 30, 2010
    Can you please try it on another Pc? If it works on another system then we'll only need to deal with your cpu not the monitor, but if isn't then, there's problem with the monitor which needs to be serviced. Please let me know, awaiting your response.
  • Lebanon Raingam
    I am still waiting for your response, even if you are unable to sort out, please let me know. It's been almost two hours now.
    I won't be able to try it on another PC until Monday. I'll let you know if it works. Thanks
  • Lebanon Raingam
    Ok, thanks for your immediate response. Good luck and once again Thank you for using FixYa.
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Falshing green power biutoon.
Verify all cables are secure, try reseating them. If the power led continues to flash, this usually means the power supply in the monitor is bad.
Oct 03, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
http://josepino.com/?howto-repair-dell
Feb 23, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
Dell E151FP 15" Flat Panel LCD Monitor Logo
147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
