Question about Jl Audio 12W3 Car Subwoofer
Subwoofers alternating rapidly
I have two of these except the 15in. models in my boat. Recently I've had a problem where the subwoofer's cone are moving back and forth very far except they are alternating, so the pressure is always equalized, causing no sound and just a loud rattling that shakes the boat because they are moving so much. Could this be a low voltage problem? The sound system does take up a lot of energy and sometimes it drains the batteries faster than the alternator can charge them. Or is it shorted out? is there a problem with my rockford fosgate head unit?
    Problem Solver:
  • 18 Answers
It sounds like you may have the speaker in the box wired out of phase. It is important that subs be wired in phase. Try switching one of the wire sets from one sub (put the + on - and vice versa.) Only do this for one of the speakers. If the connections are inside the box, you will have to get in there to do the change.
Posted on May 31, 2010
How do i rebuild the voicecoil on my kicker l7 15in speaker
I dont think that kicker has a recone kit available for L7, after they started building the cone as a one piece structure without a dustcap, making it impossible to align the coil in the gap.
Myself, i have considered the possibility of using the carbon fibre maxxonics recone kits, it may need some tweeking to make it work. but will be quite strong and you could try different coil impedences, aluminum formers etc.
if you dont feel adventurous, than you might be able to send in your sub to kicker for service. i think they just send off a new sub to you, at a discount......
Apr 14, 2014 | Car Audio & Video
I have a 1000 w dual coil and a 1000 w amp do I just hook them up positive and negative just how they are both sides just how I think it would
Hello
In most speakers, either (+ve) or (-- Ve) will be mared on its soder leads. If there is no such markings, just look whether there is a red or black spot of paint. If there it is, red colour paint mark terminal side is (+ve) and black marked terminal side is (-- ve). If there is no such markings also, take a torch cell [ a new one], contact its positive side to one terminal of the speaker, and its negative to other terminal win a piece of wire. Just touch once. Look the movement of the cone paper. For one side connection the cone paper will push out and for the reverse it will be drawn in. Note the position when the cone paper pushes out. Now note which terminal is connected with battery positive. This terminal is the positive connection terminal of the speaker. OK
Jun 25, 2011 | Volfenhag ZX-4712 Car Subwoofer
My jvc subwoofer inner speaker windings blow up and i m either willing to purchase the whole sub set or jst the inner speaker.the model number is sp-pw 105wd.theserial # 119k0101.
I would suggest to buy the entire cone speaker because the inner windings is harder to find or not available.
The cone speaker part number is: CR160058-01. Try contacting this website to find the cone speaker or you could find a cheaper speaker cone with the same dimensions and wattage.
I can also send you the service manual for this subwoofer.
Nov 27, 2010 | JVC SP-PW100 Subwoofer
My subwoofers cone keeps detaching why is this
Your amp is too much, or your gains and bass boost are set too high and the sub is distorting. Distortion happens when any of those three things are happening, basically your sub is no longer moving straight in and out and the cone is trying to compensate. This causes the cone to break away from the coil.
Aug 15, 2010 | Alpine Type-R SWR-1222D Car Subwoofer
I need to know about my 12" dvc eclipse subwoofer but i dont know what modle it is
Hello brandin_1,
I'm assuming that you have the new 12" eclipse. Look at the sub cone. If it is blue in color, you have the Model SW4210 12" DVC SUBWOOFER, 4ohm, 250W RMS,750W MAX. If the cone is silver, it is the Model SW6210 12" DVC SUBWOOFER, 4ohm, 500W RMS, 1500W MAX.
If it is an older dvc Fujitsu Ten 12" eclipse, most likely it is the Model SW9122. If it is a REALLY old 12" eclipse, it is probably a model 88120.
Hope this helps.
Apr 12, 2009 | Eclipse Car Audio & Video
Subwoofer cone detached.
you need a strong glue that remind flexable
Dec 29, 2008 | Kicker CVR12 Car Subwoofer
Subs cutting out
Agree with Kev. Even if the woven lead wire looks ok, it can still be bad. I unsoldered it, clipped a lil from both ends, and re-soldered it. Works great now.
Sep 11, 2008 | Infinity Reference 1230W Car Subwoofer
Which Jl Audio 12 Has No Writing On The BAck
http://www.simplyspeakers.com/speakerrepairinstructions.htm
go with the repair .those r good subs,very expensive. i repaired a pokl 12" sub cone and surround foam. never had a problem. save me 300 bucks.the cone you can fix by using the same material that it is made off.if paper use rubbeer glue. if plastic ,i used a 2 part epoxy,airplane glue.didn't look pretty but did the job.rating please
Feb 03, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Jl Audio 12W3 Car Subwoofer Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
